Step 1. Turn your PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep a total of 3 times and turn off again. Release the power button.
Step 3. Press and hold the power button. It will beep when you first press it, then 5 seconds later it will beep again and then it will beep twice quickly. Let go of the power button when you hear these 2 quick beeps.
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this then continue to the next step
Step 5. The PS3 will load with a menu with 6 options, choose number 5 "Restore PS3 System" and follow the on screen prompts.
Using this method should sort your PS3 out for you.
This problem is because your PS3 software has become corrupt. The following steps will cure the problem but you will lose saved games and all other data. Your trophies will not be affected as these are stored by the Playstation Network.
Step 1. Turn your PS3 onto standby (Red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it, beep 5 seconds later then beep once more 5 seconds later and then turn back to standby. Release the power button.
Step 3. Press and hold the power button again. It will beep when you first press it, beep again 5 seconds later and then beep twice quickly. Let go of the power button as soon as you hear these two beeps.
Step 4. The PS3 will start up asking you to plug in a controller with a USB cable and press the PS button. Do this and it will boot into the recovery menu.
Step 5. Choose option 5 (Restore PS3 system). This will re-install the PS3 software and restart the console.
Step 6. When the PS3 restarts you will be asked to enter the time and date and other information. When the setup is complete your PS3 will boot into the home menu normally.
You must be sure that disc are clean and free from fingerprints..this tends to affect background..! Also if you are not online.. you must plug into ethernet/broadband to "UPDATE" ps3 software at least once a week..! and any new games you buy also require Online updates..!
Turn your PS3 completely off by pressing the power button and then turning off the power switch in the back. Your PS3 should show no lights. Wait about an hour to let the system completely cool down, then turn the power switch on the back on again. Now press the power button and hold it until the system beeps. This will reset a few settings and make sure the system is OK. Hook your PS3 up using the RCA Red White and Yellow cable and turn it on again, and you should be able to be back up and running.
Try doing a master reset of your system.
1.) Turn off the hard switch on the back of your system and wait 30 seconds.
2.) Turn the hard switch back on so that the PS3 displays the red "stand by" light on the front LED.
3.) Hold your finger on the soft "on switch" (above the red LED) for about 10 seconds until the PS3 emits a beep.
Good Luck!
-Tom
