TV has worked fine for 4 yrs. Turned it on the other day and there are green and red shadows at upper and lower parts of screen. At top and bottom screen is curved in at center
I read somewhere it is possible to replace these resistors and other parts yourself. Cost of parts is 40.00. I thought I would receive a fix not an estimate ?I read somewhere it is possible to replace these resistors and other parts yourself. Cost of parts is 40.00. I thought I would receive a fix not an estimate ?
Am fine with high voltage. Use a multi meter every day at work. better with mig welder but can get by with soldering gun. ThanksAm fine with high voltage. Use a multi meter every day at work. better with mig welder but can get by with soldering gun. Thanks
You can't post conmments that contain an email address.
Sounds like you have hardware failure in the convergence circuit. Some combination of the IC's, fuses, and/or resistors has failed. Repair cost is $250-$400 parts & labor
These units carry hi volts, are you comfortable with this and handy with a multi meter and soldering iron if so post back and we shall endevor to dive in deeper for you, but I must go to work nowThese units carry hi volts, are you comfortable with this and handy with a multi meter and soldering iron if so post back and we shall endevor to dive in deeper for you, but I must go to work now
Try replacing your video cable, if that doesn't work, try using a different input on the T.V. If that doesn't fix it, you may be out of luck with out an extended warranty.
The tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or pictures look like 3D?Yes,than the tv convergence board it is dead.The tv convergence board must have it components parts replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-$350 for parts and labors.
If the Blue lines are blurs or shadows, then your Convergence IC's are going or gone bad. I have the same TV - it will be 4yrs. old in Dec. Mine started with Blue lines & shadows, then Red, Blue, Green Shadows. This is caused from over heating. The Convergence IC's have to be replaced. I have had 3 TV Repair shops all quote me a price from $350. to $400. to repair. They all said 4 years is the usual life time for these IC's. Replace the STK932-110amps with STK394-250-E or STK392-150 for greater reliability. Use only Original Replacement Parts, there are some cheaper but won't last and can't take the heat. If you are a "do-it-yourselfer" here is a link with the directions and pics. http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm Good Luck!
