20 Most Recent Akai PTH5498 54" Rear Projection HDTV-Ready Television Questions & Answers
Either the convergence chip has gone bad or the Focus block is bad. In any case,you will need to consult with a professional technician to solve this problem
Akai PTH5498 54"... | Answered on Nov 12, 2017
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Akai PTH5498 54"... | Answered on Sep 03, 2017
One or more of of the crts on set is burnt out and needs replacement.
Akai PTH5498 54"... | Answered on Oct 11, 2015
check kill switch on the lamp cover door it should be firmly pressed by the lamp door
Akai PTH5498 54"... | Answered on Jul 20, 2013
The image settings has changed it may be in sepia.. Just change it in camera setting or image setting into auto or normal ,,
Akai PTH5498 54"... | Answered on Jul 19, 2012
Short on the power and deflection boards---with set unplugged take a careful look inside for burnt or blackened parts etc.
Akai PTH5498 54"... | Answered on May 17, 2012
If you unplug the set and look with the back cover removed you will find 3 large black round lens inside---light source (red,green,blue) for your picture--clean them with a lens cloth or a paper towel with glass cleaner sprayed on the towel.
Should be done about 1 time a year.
Akai PTH5498 54"... | Answered on Apr 27, 2012
the user manual is available at the following link its delivered by download within minutes
http://servicemanuals.vstore.ca/product_info.php/pName/akai-pth5498-user-manual
Akai PTH5498 54"... | Answered on Oct 29, 2011
This is a convergence problem and fixable. Click here.
Jdvillanueva
Akai PTH5498 54"... | Answered on Oct 01, 2011
If model number is correct the akai is a samsung; from the rear with the cover removed are three rather large black lens (one for each picture tube) that point upwards.
If the set has not been serviced for a long time clean the lens with a lens cloth or a paper towel with glass cleaner sprayed on it.
These are the light source for your picture and if dusty the picture will be darker and dull looking.
SD TECH
Akai PTH5498 54"... | Answered on Sep 21, 2011
The sound of it sounds like a power board transformer that went out on you, Looking up that part lands you about $95 bucks labor about $200 depending.
So its all up to you on where you want to take it.
I did also mention trying to sale it for parts to help you sustain for a newer set.
Thanks or using Fixya.com
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Akai PTH5498 54"... | Answered on Sep 03, 2011
See my tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting for help with your problem.
Thanks for using FixYa and for the great rating.
hardrocko
Akai PTH5498 54"... | Answered on Aug 16, 2011
There could be many items that can cause that symptom. However I always assume convergence on any rear projection which can easily be checked by unplugging the convergence amp board and then plugging in the set and press power , if the set powers up turn it back off, and you will know the convergence ICs and associated resistors on that board have failed. Although its easier to replace the board unless you have good soldering skills. I am pasting a pic of the board which is suspended above the main chassis just mark the wires then unplug the set from the wall first, but then unplug the wires from that board and then try powering up the set.if you need further assistance , respond to this same post slinteriors_21.jpg
Akai PTH5498 54"... | Answered on Aug 12, 2011
Akai PTH5498 54" Rear Projection HDTV-Ready Television Logo
193 questions posted
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Akai Televison & Video
Most Popular Question
tv wont turn just
  • Televison & Video
