The T.V was working fine and one day we turned the t.v. on and we had the issue of the top of the screen dipping down a little and the red, green, and blue lights shadowed each other. I have taken it apart but need more instructions on what I should do. Any input would be helpful so add what u can. Thanks in advance!!
F1 Cartridge 20 Blue Dip beam, High Intensity Discharge (HID) light relay. F2 Cartridge 50 Red Ignition relay feed. F3 Cartridge 60 Yellow ABS. F4 Cartridge 30 Pink Rear window heater/heated mirrors relay. F5 Cartridge 30 Pink Automatic transmission control module relay. F6 Cartridge 30 Pink Heater blower relay. F7 Cartridge 50 Red Power supply to passenger compartment fuse box. F8 Cartridge 80 Black Blower module. F9 Cartridge 50 Red Engine management system power relay. F10 Cartridge 20 Blue Headlight power wash pump relay. F11 Mini Not used. F12 Mini Not used. F13 Mini 30 Green Heated front screen right-hand side. F14 Mini Not used. F15 Mini 30 Green Heated front screen left-hand side. F16 Mini 20 Yellow Left-hand dip beam, day time running lights, autolights. F17 Mini 20 Yellow Right-hand dip beam, HID lights. F18 Mini 20 Yellow Throttle motor supply. F19 Mini 15 Blue Screenwash pump, rain sensing system. F20 Mini 5 Tan Navigation display. F21 Mini 15 Blue Side (Parking) lights. F22 Mini 20 Yellow Accessories relay. F23 Mini 10 Red Air conditioning compressor clutch. F24 Mini 15 Blue Door lock power. F25 Mini 15 Blue Direction indicators (GEM). F26 Mini 15 Blue Horns. F27 Mini 10 Red Automatic transmission control module, transit relay. F28 Mini 15 Blue Ignition switch. F29 Mini 30 Green Starter motor solenoid. F30 Mini 30 Green Accessory sockets. F31 Mini 10 Red Engine management relay coil. F32 Mini 5 Tan Engine management control. F33 Not used. F34 Diode D3 Not used. F35 Diode D2 Engine management control relay diode. F36 Mini 10 Red Canister purge valve, airflow meter, throttle motor relay, power wash relay, air conditioning relay. F37 Mini 15 Blue Engine management system, blower speed controller, road speed sensor (if fitted). F38 Mini 30 Green Oxygen sensor heaters A. F39 Mini 5 Tan Variable intake valves. F40 Mini 15 Blue Automatic transmission control module. F41 Mini 10 Red Injectors. F42 Mini 30 Green Oxygen sensor heaters B.
F60 Mini 20 Yellow Power windows left-hand. F61 Mini 20 Yellow Power windows right-hand. F62 Mini 7.5 Brown Rear fog lights. F63 Mini 7.5 Brown Right-hand - front side light, side markers, rear tail lights. F64 Mini 7.5 Brown Left-hand - front side light, side markers, rear tail lights. F65 Mini Not used. F66 Mini 30 Green Left-hand power seat switches, heater module, lumbar pump. F67 Mini 5 Tan Battery back-up sounder, transit relay, HID/dip relay, automatic transmission control module. F68 Mini 15 Blue Cigar lighter. F69 Mini 7.5 Brown Telematics display, In-car entertainment head unit, antenna module, navigation module, VICS (Japan), parking aid, amplifier premium 1 system, phone handset, phone power supply module, instrument cluster, PATS module. F70 Mini 30 Green Right-hand power seat switches, heater module, lumbar pump. F71 Mini 15 Blue VICS (Japan), telephone transceiver, telephone handset. F72 Mini 15 Blue Radio head unit, CD player, navigation electronic control module, Jaguar diagnostic connector/OBDII connector. F73 Mini 15 Blue Sunroof unit/module. F74 Mini 15 Blue Instrument cluster, Premium ICE amplifier unit. F75 Mini 7.5 Brown Mirror fold back module, battery back-up sounder, air conditioning ECU. F76 Mini Not used. F77 Mini 7.5 Brown Left-hand and right-hand heated seats modules. F78 Mini 5 Tan Phone power supply. F79 Mini 10 Red Automatic transmission only: Reverse lights, reverse light switch, reverse park aid, electrochromic mirror, instrument cluster. F80 Mini 7.5 Brown Park interlock, heater switch, OBDII, blower relay. F81 Mini 20 Yellow Fuel pump control module. F82 Mini 10 Red Variable power steering, alternator. Manual transmission only: Reverse lights, reverse light switch reverse park aid, electrochromic mirror, instrument cluster. F83 Mini 15 Blue Not used. F84 Mini 5 Tan Instrument cluster, passenger airbag fascia light, seat weight sensor. F85 Mini 7.5 Brown Right-hand high beam light. F86 Mini 7.5 Brown Left-hand high beam light. F87 Mini 15 Blue Front fog lights, master light switch. F88 Mini Not used. F89 Mini Not used. F90 Mini 7.5 Brown Stop lights, cruise control. F91 Mini 10 Red Sunroof, electrochromic mirror, power windows, power mirrors. F92 Mini 10 Red Manual transmission cruise control clutch switch, ignition coils, automatic transmission rotary switch. F93 Mini 30 Green Windscreen wipers. F94 Mini 20 Yellow HID module. F95 Mini 10 Red Airbag restraints module. F96 Mini 7.5 Brown ABS module. F97 Mini 7.5 Brown Glove compartment light, instrument cluster lights, licence plate lights. F98 Mini 10 Red Mirror heaters. F99 Mini 10 Red Luggage compartment light, footwell lights, puddle lights, vanity mirror lights, interior lights, aircon control unit, roof console unit.__________________ 02 X-type 3.0l 04 S-type 3.0l 07 X-type 3.0l
FL231. FUSE.... The RCA ITC222 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and green shadows? Does it have bowing in affect on the top and bottom of picture? when you turn it on does some thin red green and blue line bow in from the top then go away. The main question to determine if you have the fl231 fuse problem is if you go into customer menu then setup do you have the "CONVERGENCE' option. If you do not. then i suspect you have this problem. In the manufactering of these sets Lead free solder is used. now there is great debate over the use of lead free. connection tend to be more brittle. cracks develop around the solder connections of the high voltage flyback transformer. this very small crack set up oscillations in the cuicit with a 400 milliamp fuse. THis fuse cant take it. When this fuse blows the processor then does not know its a projection tv with three projection tubes. it thinks its a crt tube tv. and crt tube tv dont need "convergence" so it removes the convergence from the set.
TO REPAIR... 1. Warning. this set can generate leathal dangerous voltages even unplug do not attempt if you have no experence with electronics. 2. Remove the back. there a number of torx 20 screws. 3. what you will see is a number of circit boards There will be one on the right and one on the left. the one on the right is the small signal board. the one on the left is called the power deflection board. it has a large black part with a big red or black wire coming from the top, this is the flyback.Next to the flyback on the right of it there will be three small rectangular componets tan or brown in color. these are fuses. the one in the middle is the fl231 fuse. 4. getting to this fuse can be difficult. these two cuicit boards sit on a tray that is removable. to remove this tray it is pulled out and up. BUt watch the wires.loosen the wire tyes. 5 when you get the tray up the bottom side of the board can be accessed you will now have to unsolder that fuse. one side of this fuse is under a plastic part of the tray. i have found the easest way is to cut away the plastic to get to it. if you dont want to do this you will have to remove the board. only remove half of the plastic brace 6. REPLACE FUSE RCA PART 259213 7 RESOLDER FLYBACK CONNECTIONS simply heat up and add a little solder 8 reassemble set. make sure you examine the set for loose connections. 9 and remember "BE Careful'
Hi Thanks for using FixYa. First of all please check whether all the cables from your dish network are fine and connected firmly. If yes then you'll need to pull off the front of the TV, behind the speaker grill there would be a panel. Remove the panel and check for a black box hanging over there. It has 6 controls on it, 3 are marked as focus and 3 as screen. You'll need to adjust the screen. If you turn these too high you can damage the tube. So you need to do only a small adjustment. Turn the color off on the TV and adjust the red, blue & green controls up till you get a fine picture. Also adjust the focus until you get a clear picture. And, if it doesn't resolve your issue then it is an intermittent blue picture tube, a bad blue driver transistor on the CRT board, a bad connection on the blue CRT board or a problem in the RGB coming from the video jungle IC.The price to resolve the issue will most likely run you about 300 to 500 bucks, unless it is the picture tube. Please do rate the solution and revert for further assistance. Thanks Rylee
There are many causes for spots on top of an LCD rear projection tv, you are probably in the first two cases, both require part replacements and repair job.
If the spots are faint blue, green or pink shadows, then it can be a problem with the anti polarization panel placed on top of the LCD.
Similar spots (colored shadows) may be caused by a problem with the light engine, in that case the fix will be expensive.
If the spots are bright lights, like an aura, that is a problem with the color wheel.
Problems on the light tunnel can cause static gray shadows.
If the spots are static dark stains than that is lcd liquid, the LCD panel must be replaced.
Sounds like you have hardware failure in the convergence circuit. Some combination of the IC's, fuses, and/or resistors has failed. Repair cost is $250-$400 parts & labor
