Use regular A/V cables on the ps3. Turn off the PS3 from the back. Go ahead and hold down the power button on the front and as your doing that turn on the ps3 from the back and keep holding the power button on the front for 5 seconds.
At this point it should reset the machine back to factory defaults and you should get video. Go ahead and change the video output to HDMI and reboot the system. On the reboot you should get video from the HDMI output, if you don't then that means you have a bad main board inside of fthe PS3.
hi, PS3 outputs hi definition video through HDMI ie 1080p. Your tv will not support that resolution. Because its a HD ready one ie 1080i. If you wnat to connect the PS3 through the hdmi then you have to down convert the video output resolution of PS3 to 1080i. for that you have to connect the PS3 to any FULL HD tv and go to the HDMI video setup and down convert the resolution to 1080i. After that you can connect the PS3 to you tv. Surely you will get the video.
There is one more way to get the video in you tv. connect the PS3's component video output to the component video input of you tv and the audio output to the corresponding component audio input . Select component video input on the tv. You need a component video cable and a stereo RCA cable for that. ok
hi
There maybe some problem with your TVs resolution. ps3 outputs full hd
high resolution video(1080p) through its HDMI. May be your TV is not
supporting that resolution. Connect ps3's component video out to your TV's component video input
and then try. if it ask for any resolution selection. select 720p or
1080i, above that resolution your TV will not support. Your tv is hd ready
one, not full hd. ps3 's HDMI out is full hd (1080p). or try this
Connect your ps3 to any full hd tv and then goto video setup of ps3.
change resolution to 1080i (down scaling ). then connect to your TV via HDMI. surly u will get the video. ok
Hello... This is most problem due to the cables or your audio output settings.
Ok, firstly try checking the cable's are in properly and no dust has built up. Then at the main menu, go to settings. Scroll down until you get to sound settings, choose audio output settings then HD-MI then auto. If that doesn't fix the problem, choose manual and select the most basic output.
Any further questions please don't hesitate to ask.
Thanks for using fix ya.
Ok, this is general hardware failure. This will need to be repaired by a Sony tech asap. the central board is malfunctioning at this time. Contact Sony asap.
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
if there's absolutely nothing on the TV screen, then most probably the video output is different then the cables you are using (eg: video output HD and you are using AV cables). Are you sure your TV is set correctly? like using HD cable you have to choose HDMI or AV cable choose AV. Anyway, When the PS3 is on, turn it off by pressing and holding the power button on the front (so the light turns red) you will hear beep sound ( I can't remember how many but not once). This should reset the Video output to AV. Swithch to AV cables (if you're using HD). Usually if the system is set to AV output and you switch to HDMI cables, the system recognizes that and swithches to HD output. But if it's set to HD output and you are using AV cables, it doesn't switch back; that is what my system does.
A lot of devices like PS3, HD DVD Players, Cable boxes, etc., require you to define on the setup menu if sound will be coming out of the HDMI cable or not. Most of these devices can be set to HDMI Auto, but not all of them do.
I currently have both my Blu-ray and HD DVD player outputting both video and sound through my HDMI into my STR-DG710. Both devices are setup to output sound through the HDMI.
But like the other person on here posted, it you have a DVI to HDMI cable, you won't be getting sound. The only device that will output sound from a DVI to HDMI are select computer graphics adapters like the GeForce 9800 GT series video cards, and even not all of those will have this feature.
