SOURCE: Brother DCP-120C Printer - Does
have you recently had a paper jam. somtimes pieces of paper can become trapped under the print head which restricts the printing. if there is and its been there for a while the print head may need to be wiped/cleaned( a bit tricky) then a couple more print head cleans.
SOURCE: Brother dcp-150c, black ink wont work
Ink may be new, but their nozzles may be blocked; depending
on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle
and press firmly. If the tissue comes off well blotted with ink it means you
still have a good amount of ink in it and the nozzle is not blocked. If not
blotted or scantily blotted, it means ink is really low or nozzle is blocked.
To be very sure of this, place nuzzle in a plate/saucer with a bit water so
that the nozzle is soaked. Leave for about 10 minutes. Then apply the tissue
again. If still not well blotted it means ink is really low or empty. If new
you should return it for a replacement. In the case of blocked nozzles, the
procedure may be repeated over to get results.
SOURCE: MY BROTHER DCP 120C PRINTER WONT PRINT BLACK
It should be under warranty, you print head got a problem
good chance....Print head is blocked very common, what sort of inks were used?
Not economical to repair, buy new!
All new cartridges fitted. Thank you for your useless help.
