Washing Machines Logo
Lorraine Juliano Posted on Mar 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does F21 mean on Whirlpool Model WFW9500TW03?
Thomas Perkins
Level 3:
  • Whirlpool Master 15,088 Answers
  • Posted on Mar 20, 2019
Thomas Perkins
Whirlpool Master
Level 3:
Answers
15088
Questions
0
Helped
3389914
Points
54869
1 Related Answer
Anonymous
  • 15935 Answers
  • Posted on Sep 28, 2010
SOURCE: Our washer has been displaying the codes F21 and
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Whirlpool washer. Error code F21
If you see error code F21 on your Whirlpool washing machine, this refers to a water drain problem. The washer won't be able to finish the cycle and your laundry will be wet. This error code means draining is taking too long, and something is wrong with the water pumping.
How To Fix Whirlpool Washer Error Code F21? ' WHATT.ORG
Videos as well
https://www.google.com/search?q=Whirlpool+washer.+Error+code+F21
What does code f21 on a whirlpool duet mean?
The Whirlpool washer error code F21 means the washing machine has a "water draining issue", meaning the drain pump itself, or the drain hose is clogged and the washer is having problems draining the water out. In other words, the washer is taking too long to drain the water out of the tub.
Nov. 15, 2016
Whirlpool Washer Error Code F21 - DRAINING ERROR - How ...
Videos as well
https://www.google.com/search?q=code+f21+on+a+whirlpool+duet+mean
My washer whirlpool duet steam has a code of F 21 what does that mean
5helpful
Whats f21 mean?? a new belt??
Hello, Welcome to FixYa.
Based on your post I understand you have a F21 problem with a Whirlpool Duet washer, that indicates the F21 error means an excessive drain time, the belt is a non-factor.
If you follow the link to my solution to this error you should be fixed up in no time.
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for visiting fixya for your washer inquiry.
Regards,
Macmarkus :)
I have a whirlpool frontload washer with model number WFW83005W00 and I have an error code F21 that flashes and then the washer stops working. What does this mean and what should I do?
Means the drain is taking too long . Most likely that the drain sump filter is blocked. Remove the lower front panel and unscrew the large white thumb screw attached to the pump. Water will come out so collect it then clean and replace.
4helpful
Whirlpool washer wfw8300sw02 code F21 what does that mean
the F21 code is a ' drain issue ' --- if you remove the bottom panel from the machine you will see the water pump right there,, just in front of the pump you will see a clean out area,, unscrew counter clockwise and remove the catch screen,,, it most likely has a few things in it ,, clean out - re-install and start the cycle. and the F21 code should be gone AND washer is back up and running.
c...
1helpful
2answers
What does f21 on washer mean?
Hi, this advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F21” error code.
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
  2. Check the drain hose to make sure it is not kinked or clogged.
  3. Check the electrical connections to the pump and ensure the pump is running.
  4. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Take care
1helpful
I am getting error code F21
hi there,
the F21 error means the communication between the touchpad and the control board behind it.
here is what you do:
unplug the washer
check the wiring harness betweeen the control board and the touchpad
make sure there is no corrosion on any connectors on the control board
check for any obvious burns or kinks on the control board & harness
if all of the above checks out okay, i would start by replacing the keypad first
let me know how it turns out.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
