Checking the Drain Pump on Kenmore Elite Front Loader
By
jsrock516
Rank: Guru
Rating: 96%, 6472 votes
posted on Feb 07, 2008
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
- Unplug the washer while servicing inside the unit.
- Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
- Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
- There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
- Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
- Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
- Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
- Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
- With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
- Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
- At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
- If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Was this helpful?133 people thought this was helpful
Comment #1
posted on Oct 29, 2009
By
TylerFX
Rank: Apprentice
Rating: 0%, 0 votes
So glad to found this website. Don't know if this is the same issue? But my washer spin if I put in on FINAL SPIN cycle. However, if I start the cycle, water just keep going in and straight out the drain so the cycle never started. Will this fix the problem or is my drain motor broken???? Thanks in advance.
Comment #2
posted on Oct 21, 2009
By
jwhitenh
Rank: Apprentice
Rating: 0%, 0 votes
You are the man!!! I was just about to call Sears when I decided to look around on the internet under diagnotics codes and ran across your instructions. It was easy to do, took about 10 minutes and saved around $200 in cash...too bad for Sears...ha ha ha ha. Maybe I'll take the family out for dinner tonight! I found a couple dollars in change, a dollar bill, and airsoft bb's (they do a great job plugging up the filter holes). On my machine there was no DRAIN SPIN, NO SPIN option so I just ran a new cycle and had clean clothes! Have a beer on me! - Jeff
Comment #3
By
byomtoob
Rank: Apprentice
Rating: 0%, 0 votes
Wonderful instructions and advice. I learned that airsoft bb's do a wonderful job of clogging the trap.
Thanks for your help. You made it easy.
Comment #4
posted on Oct 20, 2009
By
Bigmind
Rank: Apprentice
Rating: 0%, 0 votes
My washer doesn't drain, i have cleaned everything you mentioned, but it still doesn't work, i removed the pump, i spinned the impeller, it doesn't run well, it runs, but i can feel some resistant inside the pump, maybe the pump is damaged, but it still spins, when i put it back, i can hear the noise,no water comes out.
Comment #5
posted on Oct 12, 2009
By
brownart
Rank: Apprentice
Rating: 0%, 0 votes
Great walk thur,simple and to the point. Checking and cleaning the access should be listed as regular scheduled maintenance.
Thanks a lot....... : - )
Comment #6
posted on Sep 25, 2009
By
rcrisp109
Rank: Apprentice
Rating: 0%, 0 votes
Guru, you rock! Totally fixed my own machine for free! Sears wanted $160 just to come out and look at it! Thanks man!
Comment #7
posted on Sep 20, 2009
By
cckeown
Rank: Apprentice
Rating: 0%, 0 votes
Thank you so much. I thought I would have to pay hundreds of dollars and I learned a little about my appliance. Also it save me time waiting for someone to service my appliance. This site is fabulous!
Comment #8
posted on Sep 16, 2009
By
coupsevier
Rank: Apprentice
Rating: 0%, 0 votes
If you were here, I would HAVE to kiss you! God Bless You! Thank you, thank you, thank you!
Comment #9
posted on Sep 01, 2009
By
alruggles
Rank: Apprentice
Rating: 0%, 0 votes
Yuck! I won't gross you out with what all I found in the trap, except that I have no idea who's watch was stuck in there. YOU fixed my washer and you saved me wad of cash! Thank you so very much!
Comment #10
posted on Aug 31, 2009
By
dmh364
Rank: Apprentice
Rating: 0%, 0 votes
Bravo! Great advice and a easy fix to a BIG problem....at least my wife thought it was a BIG problem. Thank You!
Comment #11
posted on Aug 25, 2009
By
egriggs
Rank: Apprentice
Rating: 0%, 0 votes
Worked like a charm. The smelll was wretched - like a small dead animal - but worse. Lots of change.
The screwdriver used in this application is also the tool needed to disassemble the sprinker heads in the dishwasher. Every kitchen needs one of these tools to keep with the disposal wrench.
Easy chore for even an old lady.
Comment #12
posted on Aug 21, 2009
By
kewe65
Rank: Apprentice
Rating: 0%, 0 votes
Excellent - and simple instructions that should be part of the damn manual.
Who knew that THAT is where socks go when they seem to mysteriously disappear in the laundry!
Comment #13
posted on Aug 06, 2009
By
merylcoz
Rank: Apprentice
Rating: 0%, 0 votes
THANK YOU SO VERY MUCH!!! This worked perfectly. Found lots of coins, my son's guitar picks, a needle to inflate soccer balls, hair scrunchies, and the thing that was creating the most havoc was a little fabric bag by Oakley to hold sunglasses. It was fully inflated with water and looked at first like a stuffed animal.
Didn't have a shopvac, but held a huge popcorn bowl under the access opening and let water slowly trickle out. When bowl was full I resealed access cover, dumped water and repeated process. Not a drop of water got on anything!
Only problem I had with my machine was that I couldn't do the diagnostics check. I was able to set, DRAIN SPIN, and then NO SPIN, but my machine doesn't have an OPTIONS button so I had nothing to push 4 times. Tried pushing other buttons, but nothing worked. Luckily, I closed everything up, ran the machine, and it works perfectly!!!
Thanks again. You are a lifesaver!!
Comment #14
posted on Jul 23, 2009
By
krellman
Rank: Apprentice
Rating: 0%, 0 votes
Excellent solution. Worked for me as well. My trap was clogged with a half dozen color catcher sheets. After unplugging, I closed it all up, plugged in the machine, and it works fine. Only other thing to add is that inside the front panel under the door are instructions to the repair guys as to what the error codes mean. Why this is not in the manual is beyond me. Nor is it clear why they don't tell you that instructions are included there. Thanks to jsrock for posting this super helpful info!
Comment #15
posted on Jul 22, 2009
By
ralphie2
Rank: Apprentice
Rating: 0%, 0 votes
Great advice for the F2 error code on the Duet Whirlpool washer. We followed the directions and used our Shop Vac with the nozzle to **** more debris out of the black flexible drain hose. By squeezing the hose with your hand and using the ShopVac to **** out the debris we were able to dislodge chunks of a carpenter's pencil, $2.86 in coins and a button. The advice to use a garbage bag to to catch the water was a great piece of advice. Our washer was locked so we had no way of emptying the drum before we opened the drain access. We had a lot of water in the drum.Thanks!
Comment #16
posted on Jun 05, 2009
By
seabum
Rank: Apprentice
Rating: 0%, 0 votes
Thank you SO MUCH for this information!!!!! I was able to follow your detailed instructions and it solved my washer problem. You saved me the $65.00 service call and any other fees they may have added.
Comment #17
posted on Apr 29, 2009
By
dave_nance
Rank: Apprentice
Rating: 0%, 0 votes
Thanks for the detailed instructions. Very helpful. $1.87 in change,8 bobby pins, 2-hair thingies and lint.
Comment #18
posted on Mar 30, 2009
By
drinkwiz
Rank: Apprentice
Rating: 0%, 0 votes
Ok, I followed the steps and found in the plastic filter a sock, pen, two hair pins, two plastic tooth picks, two hair bands, a plastic nickel size disc and a bunch of lint. I am running a load of clothes and so far so good. The pump is still very noisy so maybe because the (F2) has been off and on for two years, it might have worn the pump out. Now I know what to look for now. Thanks!!!
Comment by drinkwiz, posted on Mar 31, 2009
Well the load of clothes was almost done when once again the (F2) appeared again. It looks like the water is still not draining all the way. I think I will disconnect the hose from the motor itself and try and flush that out. If that doesn't work then I assume it has to be the pump itself! Any one else have this problem??
Update, I removed the hoses and cleaned them out with water pressure. I disconnected the elect to the water pump motor and removed the motor. no other debris found but the water was gunky. I just ordered a new pump with motor from sears.com for $71 plus taxes and delivery fees ($91) total. So far I found it very easy to do this myself so an update will follow when the part arrives.
Comment #19
posted on Mar 21, 2009
By
str8up_us
Rank: Apprentice
Rating: 0%, 0 votes
Ok followed directions so far so good and did not have to tilt because ours are stacked. Found Zicam stick, lint, a spring, two dimes and a nickle. Thanks!
Comment by str8up_us, posted on Mar 21, 2009
Forgot to mention the a dryer sheet! lol
Comment #20
posted on Mar 16, 2009
By
peercel
Rank: Apprentice
Rating: 0%, 0 votes
I went and bought a new pump and installed. Still seem to be getting the FO2 or SUDS. Is there anything else I should check? Is there something else that could be blocking the water? This washer has always seemed to make clothes smell moldy etc. Would love thoughts....repair man coming tomorrow and I want to avoid it if i can.
Comment #21
posted on Mar 15, 2009
I checked my filter and could not find anything significant. I lookd into the black hose and only a bit of scum that I cleaned out. However at the top of the black hose I felt something that feels like plastic ball. Is there suppose to be anything there.( possibly to prevent larger objects from gettting to the filter. I would not think so. )
Comment #22
posted on Mar 14, 2009
Thank you!!!!!!!!!!!! What a simple task, unfortunately I did not see these directions until I had already popped the bottom panel off and just destroyed it!!!! I did not know about the three screws and assumed it just popped out. What a dummy. I guess I'll be ordering a new bottom piece and reinstalling but pump and filter are fine. A small wrench, about .42 cents, q-tips & lint were our culprits.
Comment #23
posted on Mar 13, 2009
Saved me big buck$ too. Thanks. 30 minutes later the sock is pulled out of the pump and the drain works fine. Thanks again!!!!
Comment #24
posted on Mar 11, 2009
By
harkpau
Rank: Apprentice
Rating: 0%, 0 votes
Thanks jsrock516,
Following your instructions, I have fixed our Kenmore washer with a F02 failure code. A small face towel was in the ACCESS. Now the washer is working great. Great instructions.
Harkpau
Comment #25
posted on Feb 26, 2009
Thank you so much. Was going to have to wait 6 days for a repairman. Read this and my washer works like new now. Baby socks! Go figure...
Comment #26
posted on Feb 12, 2009
By
rhynole
Rank: Apprentice
Rating: 0%, 0 votes
Four socks! Four 2-year old child socks! That's what I found inside the drainage valve blocking the flow. Got that out of there, put it back together - good as new!
WHOOOOOO! NO SERVICE CALL!
Comment #27
posted on Feb 05, 2009
By
rainman_or
Rank: Apprentice
Rating: 0%, 0 votes
GREAT ARTICLE!
Had an F21 error, I followed the directions... used my shop vac to remove the water from the but, took the lower cover off. loosened the trap cover slightly, used my shop vac to **** the water out of the trap as it leaked around the cover NOT A BIT OF WATER ON THE FLOOR.
Nothing in the trap but TA DA! TWO BALLOONS IN THE INTAKE FOR THE PUMP MOTOR LEFT FROM MY SON'S PANTS POCKET!
Hooked the balloons with a bent piece of 12ga wire and out they came. Re-installed the trap cover and lower cover and IT IS WORKING GREAT!
This page saved me at least $200 for a repair visit! THANKS SO MUCH!
Comment #28
posted on Feb 02, 2009
By
NJmomof2
Rank: Apprentice
Rating: 0%, 0 votes
I had a lots of lint, hair, bottle cap, stones, jewelry, coins, broken Christmas ornament, several straight pins? and even a panyliner in the trap! My machine does not have "Option" button so I hint Drain and Spin...so far so good ! Thanks !!!
Comment #29
posted on Jan 30, 2009
Great free advice.. Found 4 tweezers $2.00 in coins and socks. I wish this was in the troubleshooting manual.. Thanks for saving me $200. My washer is working finallly after two weeks of messing around. I had gone as far as cutting of a piece of my drain hose. You made me a life member
Comment #30
posted on Jan 26, 2009
By
pooh411
Rank: Apprentice
Rating: 0%, 0 votes
Thank you very much. My washer is working now. Your instructions were very clear. I cant believe i did it. I had coins a tooth pick and beads in my trap and a sock in my hose leading to the trap. I did-nt even know there was a trap.
Comment #31
posted on Jan 25, 2009
By
jenifree
Rank: Apprentice
Rating: 0%, 0 votes
90 cents, a sock, an inkpen, and a while bunch of lint later...my washer is working again!!! Thank you SOOOOOO much!
Comment #32
posted on Jan 22, 2009
By
papasome
Rank: Apprentice
Rating: 0%, 0 votes
Thank you so much. Why couldn't Sears just tell you to clean out the pump on a regular basis - simple maintenance. Now htat i think about it, the washer has been draining slow for months. I could not believe what we pulled out of the filter. What a great website!!!
Comment #33
posted on Jan 17, 2009
By
Zippers
Rank: Apprentice
Rating: 0%, 0 votes
Thank you so much for taking the time to write this advice!!! When my washer wouldn't drain the first thing my husband said was we had to call someone out in the morning. I didn't want to spend the time or the money to do that so I looked online and found your advice. I am so glad I did!!! My husband did just as you said and it worked the first time! You saved us time and money and we are grateful! Thanks again!!
(I had gunky hair and 1 hairband in mine)
Comment #34
posted on Jan 11, 2009
By
loooney2ns
Rank: Apprentice
Rating: 0%, 0 votes
2 hair bands, a ring and a toy. When I first tried it, it still didn't drain. The second and third time worked. I'm getting ready to put it back together. Thanks!
Comment #35
posted on Jan 09, 2009
By
ciscoed
Rank: Apprentice
Rating: 0%, 0 votes
Thank YOU!
Comment #36
posted on Jan 05, 2009
By
sshim
Rank: Apprentice
Rating: 0%, 0 votes
Thank you so much! It worked - there were 3 socks in the trap clogging the drain!
Comment #37
posted on Dec 30, 2008
By
tappej
Rank: Apprentice
Rating: 0%, 0 votes
you are a god!!! thank you!!
Comment #38
posted on Dec 15, 2008
yes! thank you so much, the pump basket (the bit knob you turn open) had a rock in it (from our kid's pocket!). Once removed the machine worked fine; and $!25 service call saved! Do this before calling sears!
Comment #39
posted on Nov 10, 2008
By
embeach
Rank: Apprentice
Rating: 0%, 0 votes
Thank You, it worked perfectly.
Comment #40
posted on Nov 09, 2008
By
BobOso42
Rank: Apprentice
Rating: 0%, 0 votes
Hi! Thx for the tip! This was so helpful. My only issue was that my model didn't give me the diagnostics mode as directions explained. I was able to run a rinse/drain cycle for the fill-time, then switch to the spin/drain cycle to make sure all was working. Thx. You're a life saver. Fred
Comment #41
posted on Oct 28, 2008
By
hisbride88
Rank: Apprentice
Rating: 0%, 0 votes
Thank you! thank you! thank you! We got it done!--- it was so simple that even i could do it : ) In my case, there was only one screw rather than 3.... the only cost i had was for the screwdriver, as it was the torque type-- (torx?)..... just think of how much was saved.... and this is a single mom here, never done anything like this-- wow, so rewarding (though really, it was so simple, wasn't it?).... what a big difference it made just to remove a tooth pick, penny, and a few other little what nots and gunk, not much in there, but as soon as i pressed rinse drain, that baby started turnin' again! thank you mr. jsrock... and especially, thank you Jesus! (mother of 5 in IL....)
Comment #42
posted on Oct 26, 2008
Thanks so much for posting this tip! It's very annoying that the user guide doesn't have this as an obvious solution to a drain problem.
In our case, we found a sock, two straps from my daughter's dress that had disappeared, 2 quarters, 2 nickels, 4 dimes, 1 penny, various beads & jewels from my daughters' play things, hair clips, hair bands, and a bunch of hair and dirt. Amazing...
Comment #43
posted on Oct 10, 2008
Excellent fix!
I printed your instructions and was able to easily follow them completely. Didn't find much in the trap but it was pretty nasty with gunk. Washer seems to be working just fine now.
Thanks a ton!
Also, there is a product called Affresh that is supposed to take care of moldy washer tub smell and some of the build up of left over soap/fabric softener.
Comment #44
posted on Sep 30, 2008
By
jcilker
Rank: Apprentice
Rating: 0%, 0 votes
How do I unlock the door to get the wet clothes out?
Comment #45
posted on Sep 28, 2008
By
cmanton
Rank: Apprentice
Rating: 0%, 0 votes
This is a great solution. Our washer would take forever to finish the last minute or two of the cycle. I kept spinning and would take up to an hour or more, sometimes we'd just cancel the cycle. I followed the instructions, and it worked like a charm. One trick I did was I put the hose of the wet vac right on the pump drain as I twisted it to open. Water would flow out slowly from the bottom and into my wet vac. It took maybe 10 minutes to drain before no water came out anymore. Then popped out the drain catch and found my 6month old's sock, super crusty from soap residue blocking the catch. I removed it, cleaned out some lint, and put it back as indicated in the instructions. Ran the diags, good to go. Thanks alot !!
Comment #46
posted on Sep 22, 2008
Thanks so much. It took all of 5 minutes. Turns out 11 finish nails, a broken lighter, a mower key, 52 cents and 2 children s socks can really clog up a washing machine.
Comment #47
By
dayna73
Rank: Apprentice
Rating: 0%, 0 votes
thanks sooooooooooooo much! you were right on with EVERY DETAIL of the process!!
Comment #48
posted on Aug 28, 2008
By
sweetmimi
Rank: Apprentice
Rating: 0%, 0 votes
Thank you! Thank you! The pump was clogged with a sock. It was very easy to do, and saved me from paying Sears, not to mention going a week without my washer! MUAH!!
Comment #49
posted on Aug 03, 2008
Thank you so much! not only was I able to fix my washer but it was $15 dollars that was clogging up the drain!!
Can you Help with these Washing Machines problems?
Kenmore Elite 45986 Front Load Washer
code f02 ocurs
I have an elite calypso washer and it will not let me...
agitator makes loud noise during wash and rinse cycle....
How do I change the front door gasket on a Kenmore Elite...
My washer makes loud noises when turning. Noise is from...
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
(800) 357-1234
Welcome to Action Appliance Repair. We have...
