SOURCE: I tried to change the
There could be a couple of general reasons for this to happen.
First, the tension in the bobbin holder could have tightened when you were trying to fix the needle. I don't explain them, I just know strange things happen when you try to fix one thing.
Secondly, I can't tell how old your machine it, but I know that the mechanism that holds the bobbin holder can become jammed and the thread wound around it. That too will cause the bobbin to not feed properly. You need to be sure the area around the bobbin holder is clear of all threads.
How did you try to change the position of the zipper foot? Did you just change the needle position and move the foot to the other side or did you do something else? I'd need to have more information to tell you anything more specific.
SOURCE: The small bar that holds the zipper foot on broke.
There will be several zipper feet available at any of the sewing machine stores. You can either take the broken foot with you (or another foot for the machine) or note the shank length and the bar length on the foot. I believe the White uses a low shank foot. In that case, you would get a foot that is designed as a low shank foot (assuming the bar isn't narrower than your current foot), and it will work.
The common Foot styles are low, high and slant.
I hope this helps.
(you can also order sewing machine feet online but you need to know the style of how the foot connects to the machine. The easiest way to do that is to compare it to similar feet in a local store. Most of the online vendors will list the machine brands that are compatible with a given foot. However, I know that Husqvarna low shank feet have changed width over the past 30 years and thus not all of the feet from a new machine are mutually compatible with those for an older machine. So I wouldn't guarantee the match without seeing the feet side by side.)
SOURCE: Hello, just a few quick
The easiest way to know is to look at the bobbin case and if it has a finger sticking up then it is oscillating, plate If you have snap on feet to take the foot off just push the front of the foot up, to put the foot on, rest the foot on the needle plate then lower the presser bar down on top of it to snap on
SOURCE: have lost the zipper foot for a pfaff hobbymatic
You should be able to buy another foot, but you'll need to know if it is a high shank or a clip on style. Try this link to www.sewingpartsonline.com http://www.sewingpartsonline.com/pfaff-sewing-machine-presser-feet.aspx they have two invisible zipper feet and two clip on ones. Don't mention your model but you should be able to email and ask if you aren't sure. I'd expect that the feet would be interchangeable between the models in the same era as yours. Just ignore the long funny shaped feet, they are for Pfaff sergers.
Please add details in the comment box...
What is machine make and model?
