Apparently a Western Auto brand sold in the 1950's, 1960's, and 1970's.
Google shows some Amazon.com manuals for sale:
Example of one:
https://www.amazon.com/gp/offer-listing/B01N5VWE77/ref=dp_olp_used_mbc?ie=UTF8&condition=used
Any repair shop can xplain for free
SOURCE: need correct setting for 30 yr old upright Kenmore freezer
depend on the type of control you have on your box ,,,, best is if it shows 1-7 set it on 3-4 ,, if it has letters set it on C ,,, eather way set the control on mid-point and it will work fine.
Larry
SOURCE: I have a frigidaire freezer upright model#ffu20f9gw3
Without any additional info, there are a lot of possibilities:
1. Condenser coil (underneath unit) is dirty and clogged.
2. Compressor is failing. (need A/C tech)
3. Metering device is clogged. (need A/C tech)
4. Refrigerant charge is low. (need A/C tech)
5. Door seal is broken (frost will form around door).
6. Defrost heaters are stuck on (replace defrost timer located underneath unit at front).
7. Condenser fan has failed (underneath freezer on back).
8. Evaporator fan (inside fan) has failed (ice will form on cooling coil).
This should get you started...
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
SOURCE: sears model 253.9280212 UPRIGHT FREEZER NOT
make sure the unit is running and not shutting down to soon if it is change the cold control if unit is staying running the replace unit
Hey friend, thanks for your post!
From my understanding you have recently moved your Frigidaire freezer and it is now displaying the "OF". Normally, that stands for off you should be able to press the "Up" or "Down" arrow three times within five seconds to start your compressor. If you still need a copy of your manual could you provide me with your model number? You can locate your serial tag (which lists your model number) on the inside wall of your freezer. I hope this has been helpful. -Matt
