20 Most Recent Igloo Cooler Igloo Portable Countertop Ice Maker, White Questions & Answers
i had the no ice making issue , it was running water in the tray but not enough to make the ice. I call service for the machine it self and they told me to . 1. turn machine on . 2. press the select button for 10 sec. then 3. press the power button for 10 sec. and then turn off the machine and unplug it for 6 hour but I only did it for 1 hour. when I plugged it back in and started it. It is now making ice.
Igloo Cooler... | Answered on Jun 05, 2019
it may be caused cooling problem.
Igloo Cooler... | Answered on Apr 26, 2019
Hi I had the exact same issue after about a year of running my igloo ice maker non stop. To fix it I held in the on/off button and select button at the same time for about 30 sec and TADA!! Back to making ice.
If that doesn't work I've also read to leave machine unplugged for 6 hrs and then hold in on/off button for 10 seconds. Good Luck!!!!
Igloo Cooler... | Answered on Nov 21, 2017
I searched forever for an answer to this and never found one. So this is what I did when you take the cover off on the left hand side there are two switches with two wires coming from.each switch. Then in the same group of wires the is two slightly larger wires one red one black. Those wires go to the optic eye that tells the machine is full. Cut and splice these teo wires together coming from the circuit board this will tell the machine it is empty and should make ice. Worked for me. It just doesn't cut off on its own whenever its full.
Igloo Cooler... | Answered on May 23, 2017
Run about 3 cycles of vinegar; then rinse with water. Run regular water through and then the ice should lose the chemical smell and taste.
Igloo Cooler... | Answered on Apr 18, 2016
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Igloo Cooler... | Answered on Apr 12, 2016
Igloo Cooler Igloo Portable Countertop Ice Maker, White Logo
34 questions posted
Top Igloo Cooler Freezers Experts
freddyfox
Michael Youngman
Michael Youngman
Renee Knafel-Bullock
Are you an Igloo Cooler Freezer Expert? Answer questions, earn points and help others
View Most Popular
  • Igloo Cooler Freezers
Most Popular Question
igloo countertop ice machine says tray
  • Freezers
