<span>Your Phone Bettery Fault So Please change Bettery<br />First Bettery charging Full and Swich On The Phone <br />I Hope Problem will solved</span>
First Option: mostly nokia chargers doesn't make problems... just try the following.. connect ur mobile with a system (usb cable)... found out whether it is charging or not... if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)... if it charged with usb cable buy a new charger Please change Phone Bettery and check the charging IF Charging Problem not Solved So
Secend Option: Your Phone charging IC Fault So Please change charging IC And charging Problem will Solved Quickly
Logged on to the support site of DELL w/c is www.support.dell.com and then Update the specific BIOS update for your system so that the battery will be recognized.
Sir,
you are suggested to check if your bettery is not have got expired. please try changing bettery.Some times betteries get blow up by over charging.hope it will work
to improve the battery life always charge it with switch of the mobile>and do not charge if u got 1 or 2 poing loss>and dont play games >and maximum do not use the vibration>and always use low bright ness>and and always chanrge only one hour if still the same make sure teh battery is original
Read camera manual. Generally battery position is near click button or memory card slot.
From your problem description it seems that eighter your bettery is spoiled or it is fully charged and having power supply problem or not properly installed.
Ensure that if your battery is new and the + and - terminals of battery is exactly as per your camera connecting terminals. Sometimes people insert batteries with opposite termnals which does not woerk.
