FixYa.com
BenQ FP71G 17 in. Flat Panel LCD Monitor
All Products > BenQ > Monitors
Problems with BenQ FP71G 17 in. Flat Panel LCD Monitor?
Troubleshooting and Support
Solved Problems for BenQ FP71G 17 in. Flat Panel LCD Monitor RSS Feed Post a New Problem
screen has power but is black
hi, if i press the power button to turn on the screen, for a split second the benq symble appears, then black. I have...
1 Solution
BenQ FP71G+ power supply problem
This may sound like a silly question, but how do you tell which electronic components may be faulty? Also, how do you...
1 Solution
BenQ FP71G+ screen blank
El... Great post in one of the forums describing how to check whether the monitor problem is with the inverter board (or...
1 Solution
Re: FP71G+
I agree with replacing the inverter board, but where can I get this board from? Many Thanks, Jonathan email:...
1 Solution
Benq screen shuts down when pc is plugged...
Hi I have an FP71g screen that turns off when my pc is connected. My kids lcd screen does not cause this same problem.I...
1 Solution
Monitor goes blank automatically after...
I bought this monitor about a year ago and has been working fine till last week. One day, my monitor just go blank. I...
5 Solutions
how to open casing
hi, my benq lcd monitor dont have power at all. i plan to see it if it is just the fuse.i already unscrewed my lcd but...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for BenQ FP71G 17 in. Flat Panel LCD Monitor RSS Feed Post a New Problem
BenQ FP71E doesn´t gives video
Hi! The problem with the LCD monitor primarly is the lack of video when the PC boots, but If give some firm knocks on...
Post a Solution
samaung monitor sync master 403t
gray shadow when the screen is white
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Aspect Ratio5:4 (Regular)
Size17"
Color Depth24-bit (16.7M colors)
Contrast Ratio500:1
Brightness260 cd/m
Max. Resolution1280 x 1024
Dot Pitch.264 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time12 ms
Viewable Picture Size17 in.
Technical Features
Form FactorDesktop
Regulatory ApprovalBSMI · CE · FCC Class B · C-Tick · CSA · VCCI · CB · TUV-GS · ISO 13406-2 (Pixel defect guidelines) · TCO-03 · TUV-ERGO · GOST-R · CCC · FIMKO
Synchronization Range - Horizontal30 - 83 kHz
Max. Viewing Angle - Horizontal140
Max. Viewing Angle - Vertical130
Native (Recommended) Resolution1280 x 1024
Synchronization Range - Vertical56 - 76 Hz
Dimensions
Depth5.3 in.
Height14.9 in.
Width14.3 in.
Weight8.4 lb.
Warranty
Warranty3 Years
Supported Models
Black, Black, Silver
BenQ Contact Information
Main support number(866) 600-2367
Support FAX(949) 255-9500
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
