20 Most Recent
Sony Ericsson W800i Cellular Phone Questions & Answers
I forgot my sony ericsson wg3 security code
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
I forget my phone lock
forget my phone lock code sony ericsson w880i help i forgot my phone code ,i was not using it for a while.now i don't know what to do..what can i do? my phone is a sony ericsson w800i
Mobile -hang
If u have a memory card in your mobile then try removing it first.If the card has some problem then the mobile works irracticaly(eg. hangs or restarts).
Bluetooth
Well BT is only a VERY short range device 2 - 3 feet or a metre or so is about normal... unless one has a high power BT...
I can not open mms i received
make sure your settings regarding mms allows your phn to receive and get the mms. Go check the messaging settings. thankU!
Http://mmvd.aicent.net/mmv2? how can i open?
http://mmvd.aicent.net/mmv2?pw=945572 with your MSISDN as useridthis mah link of mmsbut i cant get itcoz i cant find mah user idany one tell me that which is mine user id in this link??
How to delete accounts
I would just factory reset the phone from the settings menu. That will erase everything and place the phone to default settings. Hope this helps.
Reset phone lock code
Download this Software and update your software to reset or restore to the orginal settingsuse usb cable - from phone to usb/computerhttp://www.sonymobile.com/global-en/tools/update-service/
