Video Cameras Logo
Christine Cloyd Posted on Nov 13, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a manual for cc6363 - Video Cameras
Terry
Level 3:
  • Video Cameras Master 11,377 Answers
  • Posted on Nov 13, 2018
Terry
Level 3:
Answers
11377
Questions
Helped
4626814
Points
152765
Possibly free manual if it is the same manufacturer, RCA .
https://www.manualslib.com/manual/312924/Rca-Cc6363.html
RCA CC6363 User Manual
RCA camcorder model # CC6363 is stuck in safe mode and I can't eject my tape, how do I solve this?
http://www.google.co.nz/search?sourceid=chrome&ie=UTF-8&q=RCA+camcorder+model+%23+CC6363+is+stuck+in+safe+mode+fix
Hi at the above link, you will find a myriad of people with a problem exactly the same as yours, it is a real headache, with NO real, well DIY fix, sorry, it appears that RCA will repair it for a price, so maybe it would be simply best to bite the bullet, and take it to a professional RCA servicing center, but ONLY ask for a "Quote". Now when you get this information, then you can make up your mind as to what to do, repair or replace?
As an aside here, and it is mentioned in that link i give you above, that this problem is a "Known About Issue" and in some countries they have been made to repair this issue FREE of charge to customers...
I actually haven't come across this exact type of problem with this exact type of camcorder, however, in my shop, I have seen similar repairs etc, and they can cost upwards of $200.00, so make sure you always get that quote. Further, there are a few postulated "Fixes" in that site given too, you can not do any real harm in trying any or all of them, especially the one about cleaning the "Heads & tape transport path" as described, this may just work, as may the Battery Removal/Replacement ... so good luck.
GOT A AUTOSHOT 200X CC6363 THAT EVERY TIME YOU TURN IT ON GET ERROR CODE E04 & WHAT DOES IT MEAN
E04 - Battery in Safeguard mode.
The most common problem with this kind of model. there actually no fix for this problem. Unless of course your a jvc technician and can manage to open and clean all the sensor inside.
Have you tried to most popular solution for that.. tapping a little bit on the side of that camera. lol.
Look closely with the memory card, make sure it is inserted properly. push it a little more.
You may need to remove the battery from the battery pack and then reinsert again before turning it on. Doing it a few times may help solve the problem.
I do suggest you remove the battery when not in use. Leaving the battery inside is the usual cause for having the E04 when turning it on.
Hope this helps.
Mace1Mace
CAN YOU DOWNLOAD TO A COMPUTER FROM THE RCA CC6363 CAMCORDER. THANKS
Hello :
Yes you can . You need to download the driver for your Camera first .
PLEASE DON'T FORGET TO RATE .
good luck .
How can I play my JVC Mini Dv camer on my fltscreen? I used a USB cable to connect the camera to the TV, but I cannot get it to play on the tv.
There should be a S-video out port with most newer tvs support. You may have to go somewhere like Radioshack to get a s-video cable which plugs into the tv. then set your tv inouts to use the s-video port and play away!
Camcorder won't record
Check the tape and make sure the record tab is still on the tape and has not been removed. If the record tab has been removed then use a new tape for recording as the unit will not record. This tap is usually on the lower left end of the back of the tape. When the tap is present it closes a record mode switch letting the system know the tape is able to bv recorded on..
Can't play back my JVC Video Camera on TV screen
it is possible that the movie format on your camcorder is not one that is recognised by your TV
6helpful
3answers
Driver for JVC DV cam model no-GR-DA 30U
drivers de la camara jvc GR-DA30U ¿Donde los descargo?
Safe mode
Tell me what to do or do you have a manual for sale.
Top Video Cameras Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Video Camera Expert? Answer questions, earn points and help others
