Question about RCA CC6363 Camcorder
Camcorder won't record
I have an old RCA vhs camcorder. When I push 'record' button, the unit just doesn't record... the vhs tape doesn't move but the power is on .
Posted by curtinl on
Lavell Turner
    Genius:
  • 1,112 Answers
Check the tape and make sure the record tab is still on the tape and has not been removed. If the record tab has been removed then use a new tape for recording as the unit will not record. This tap is usually on the lower left end of the back of the tape. When the tap is present it closes a record mode switch letting the system know the tape is able to bv recorded on..
Posted on Dec 27, 2009
Hello! I have a RCA VHS-C camcorder that has a malfunctioning viewfinder.
Interesting that it has worked so long. You might want to consider a better camera since even the cheapest digital video camera today will have better video than a VHS-C camcorder. With the VHS tape it only recorded analog signals and each copy of the tape would degrade. Most cellphones today will take video that is orders of magnitude better than a VHS-C unit . . .
Aug 17, 2017 | RCA Cameras
CLASSIC RCA AUTOSHOT VHS CAMCORDER.(DSP3) PROBLEMS
The vhs camcorder has very complex mechanics and hold many traps for the inexperienced.
I suggest you begin by obtaining a standard vhs recorder and remove the cover to expose the interior and then study it. You will find the engineering and interior geography of your camcorder similar.
The round shiny barrel-shaped thing contains the record and playback video heads and the sound head is separate and looks like a larger version of what can be seen in a standard audio cassette recorder.
The interior must be extremely clean, the drive belts in good condition and the clutches and rubber rollers also in good order.
Nov 16, 2017 | RCA CC6151 Camcorder
Toshiba dvr670ku - vhs tape won't play, shuts recorder off
look to see if tape will fully load and if FF or REWIND work, if not a transport problem, drive mechanism not moving the tape, unit will sense this and shut unit off----even a problem in the loading mechanism for the VHS tape not loading the tape all the way will do the same thing.
Oct 14, 2012 | Toshiba M754 VCR
TAPE MECHANISM WON'T ROLL THE TAPE, IN EITHER RECORD OR PLAYBACK
Problem with the tape transport mechanism; could be the rollers are not contacting the tape itself or it could be the springs in the transport. Sounds like an older model. Could clean the rollers with alcohol and swap and if you can open it a like observe what happens with the rollers when you place in playback. These are rather delicately adjusted machines. I would again 1) try cleaning as best you can and very light oil in moving joints/gears aferward. 2) check adjustment of springs when moving from stop to playback. Once you have that whipped the record mecanism may start working as well.
Apr 02, 2012 | RCA CC4393 VHS Analog Camcorder
Dose it have memory. can it record with out a tape?
No, the unit cannot record without a tape.
Unlike digital units which can have internal memory, analogue recorders have no internal (built-in) tape. Analogue recorders also do not have digital memory in place of an analogue tape.
Jun 12, 2011 | RCA CC641 VHS-C Analog Camcorder
I have a JVC DR MV7SU DVD/Video recorder. How do
If your camcorder allows you to connect to a tv or vcr and allows you to record from it to the camcorder via the rca video input, then you should be able to record it that.  The camcorder must have the RCA audio/video inputs on it to be successful.
enov8
Mar 08, 2009 | JVC Televison & Video
Need unit to put tape into, to play in vcr
What you need is a VHS C adaptor. I did a Google search and found at least 10 sites selling them. Rather than cut and paste, I suggest you go to Google and type in "VHS C Adaptor".
Oct 29, 2008 | RCA CC6263 Camcorder
Recording Snow
If you hook your VCR up to the RCA jacks on the front of the DVD recorder, push 002 on the remote to use the front input jacks. (001 if you hook your VCR up to the rear input jacks)
Push record on the DVD recorder, and push Play on the VCR.
(Pg. 35 in the manual)
When you push play on the VCR, you should be able to see the movie being played on your TV. If you cannot, make sure your RCA cables are good and hooked up correctly.
That's all you have to do, so if it's not recording I would try to take the unit back for an exchange.
Dec 03, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Convert miniDV to VHS
You use the mini to triple RCA cable with the camera and go into the menu and make sure you are on A/v out instead of headphones. You just hit play on the camera and record on the VCR and Whala, it's done.
Videoteacher
Nov 26, 2007 | Canon ZR70MC Mini DV Digital Camcorder
Connecting zr85 to vcr to record vhs tape to dv or sd card
I also have a Canon ZR-- left of the lens and the built-in microphones, there is a small panel that opens to reveal several ports. The middle yellow one is the AV In/Out. You can plug in the cable that came with your camera. One end looks like a microphone plug, the other has 3 RCA type plugs- red, white and yellow. These get plugged into your VCR's OUT plugs on the back of the VCR. Place a tape in the camcorder, open the LCD panel and push the REC PAUSE button. On the VCR, press the Play button. When the tape reaches the point you want to begin recording, press the camcorder's Play/Pause button. When you want to stop recording, press the Stop button on the camcorder.
This is also detailed on page 82 of your manual, manuals are available online at Canon.com. Your specific manual is at: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=174&modelid=9739#DownloadDetailAct
Hope this helps.
Nov 20, 2007 | Canon ZR85 Mini DV Digital Camcorder
Open Questions:
RCA CC6363 Camcorder Logo
Top RCA Video Cameras Experts
Lawrence Oravetz
ADMIN Canada
ADMIN Canada
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
