20 Most Recent Panasonic NV-VX57 Mini DV Digital Camcorder Questions & Answers
Battery cost 28 USD$ for this camera.
Panasonic... | Answered on Jan 21, 2011
use http://www.downloadvideos-convert.com/download-videos-music
Panasonic... | Answered on Jun 24, 2010
If you mean to download a full file , just copy the files from the DVD and load into your computer , the hard disc.
But if you want to copy DVD into to write another DVD( copy) the use a software( NERO) to copy and write. Load the DVD to copy and click the nero link for copy then after the image is made onthe computer you must remove the disc and insert the DVDRW to be written.
Do as it commands on the software.
Panasonic Video... | Answered 4 hours ago
MOST CAMERAS HAVE TO BE OFF WHEN TRYING TO DO THIS FUNCTION AND LET THE PC FIND THEM THEN TRANSFER TO PC READ THE MANUAL
Panasonic Video... | Answered on Jun 07, 2019
Unfortunately, Panasonic does not support the VDR-M70 with Windows 7 or 8. See the FAQ here: https://shop.panasonic.com/support-only/VDR-M70.html?t=manuals . The camcorder was released with drivers for Windows 98 (second edition), Me, 2000, and XP.
If you have Windows 7 Pro, you can check if your system supports a virtual computer environment. If you can load a virtual OS, enable virtualization in turn on/off Windows features. (Go to the Control Panel under Programs. Then click on the link. Scroll through the list to find the desired line and check the box.) The XP mode software is available here: https://www.microsoft.com/en-us/download/details.aspx?id=8002 . Install the program (including setting up the disc space needed). Then launch the OS and install the software and camcorder driver in the XP mode. Use the directions for installing the VDR-M70 with a computer from the manual, starting on page 130: ftp://ftp.panasonic.com/camcorder/om/vdr-m50pp_en_om.pdf . I haven't found an online source for the Panasonic software download for the VDC-M70. Panasonic's recent software is here: https://av.jpn.support.panasonic.com/support/global/cs/soft/download/ .
I hope this helps and I wish that I had better news for you.
(I did run XP mode on a Windows 7 Pro desktop computer with an Intel i5 chip and 8GB of memory. I put in a second hard disk to ensure sufficient space for the second OS. It was a convenient way to maintain support for some older hardware and software.)
Panasonic Video... | Answered on May 24, 2019
Sounds like the screen has either failed or the wiring to it has got a dry joint or become disconnected.
Panasonic Video... | Answered on May 19, 2019
Check your connections first. Usually a camera comes with software to allow transfer from camera to computer. If it has worked before, then there is a connection problem now. Windows media player supports many formats of video. Each format type is determined by the file extension, for example .mpg .mts .avi etc. If the camera records in an uncommon format, you may need to load a different CODEC (Compression/decompression program).
See here for all formats that windows media player supports:-
https://support.microsoft.com/en-gb/help/316992/file-types-supported-by-windows-media-player
The Panasonic PV-GS35 will let you record digital media to the mini DV cassette if the other video source has a DV input/output connection. Then you use the 4-pin to 4-pin Firewire DV cable, PV-DDC9 . This cable is available from Amazon, https://www.amazon.com/LETO-FireWire-Panasonic-Camcorder-PV-DDC9/dp/B00MLQVMSK , and other vendors. The digital camera doesn't have the S-video input needed to record from most other sources.
For information on the digital dubbing feature, see the manual starting on page 42. Panasonic has the manual on the product support page: https://shop.panasonic.com/support-only/PV-GS35.html . The current link to the manual is ftp://ftp.panasonic.com/camcorder/om/pv-gs19_en_om.pdf . See page 13 of the manual for the location of the DV port.
I hope this helps.
Panasonic Video... | Answered on May 11, 2019
Have you looked at the information and instructions contained within the manual ?
Panasonic Video... | Answered on Feb 22, 2019
.Prg files are database files. They could be associated with an indexing system for that camera. They are not in and of themselves a video file.
Panasonic Video... | Answered on Jan 28, 2019
Google (Panasonic)(nv-gs27)(manual) without parens.
Panasonic Video... | Answered on Jan 26, 2019
The play head did not retack fully to the off position. Drop the player an inch from the floor to jar it into place. Or or open the back side to reach in to move parts or open stuck latch.
Panasonic Video... | Answered on Jan 21, 2019
Hello, Tariq -
Fixya.com, where you posted your question, does no repairs of any items. It is a website intended for only asking and answering questions on how to go about repairing things. You have only stated that your camera is damaged and not what you think is damaged.
I would direct you to an authorized Panasonic camera repair service in the area where you reside, but I have no idea where that is.
I suggest you use your favorite search engine (Google, Bing, Yahoo, DuckDuckGo, etc.) and the following search phrase, using quotation marks as shown to identify camera repair businesses where you reside:
"Panasonic camera repair"
You can add you location information to the search phrase, if you wish:
Examples:
"Panasonic camera repair" "Sandusky, Ohio"
Or
"Panasonic camera repair" "Birmingham, England"
Or
"Panasonic camera repair" "Manila, Philippines"
Best wishes.
Panasonic Video... | Answered on Jan 13, 2019
Panasonic NV-VX57 Mini DV Digital Camcorder Logo
8 questions posted
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Video Cameras
Most Popular Question
prize list
  • Video Cameras
