Question about RCA CC6373 Camcorder
RCA camcorder stuck in safeguard mode.Model # CC6363, how do I solve the problem?
Posted by mistyhollow on
Janice Thomas
    New Friend:
Rca stuck in safe mode , how to get it out.
Posted on Oct 13, 2012
1 Related Answer
SOURCE: RCA camcorder model # CC6363
http://www.google.co.nz/search?sourceid=chrome&ie=UTF-8&q=RCA+camcorder+model+%23+CC6363+is+stuck+in+safe+mode+fix
Hi at the above link, you will find a myriad of people with a problem exactly the same as yours, it is a real headache, with NO real, well DIY fix, sorry, it appears that RCA will repair it for a price, so maybe it would be simply best to bite the bullet, and take it to a professional RCA servicing center, but ONLY ask for a "Quote". Now when you get this information, then you can make up your mind as to what to do, repair or replace?
As an aside here, and it is mentioned in that link i give you above, that this problem is a "Known About Issue" and in some countries they have been made to repair this issue FREE of charge to customers...
I actually haven't come across this exact type of problem with this exact type of camcorder, however, in my shop, I have seen similar repairs etc, and they can cost upwards of $200.00, so make sure you always get that quote. Further, there are a few postulated "Fixes" in that site given too, you can not do any real harm in trying any or all of them, especially the one about cleaning the "Heads & tape transport path" as described, this may just work, as may the Battery Removal/Replacement ... so good luck.
Posted on Jun 27, 2011
RCA camcorder model # CC6363 is stuck in safe mode and I can't eject my tape, how do I solve this?
Jun 27, 2011 | RCA CC6373 Camcorder
GOT A AUTOSHOT 200X CC6363 THAT EVERY TIME YOU TURN IT ON GET ERROR CODE E04 & WHAT DOES IT MEAN
E04 - Battery in Safeguard mode.
The most common problem with this kind of model. there actually no fix for this problem. Unless of course your a jvc technician and can manage to open and clean all the sensor inside.
Have you tried to most popular solution for that.. tapping a little bit on the side of that camera. lol.
Look closely with the memory card, make sure it is inserted properly. push it a little more.
You may need to remove the battery from the battery pack and then reinsert again before turning it on. Doing it a few times may help solve the problem.
I do suggest you remove the battery when not in use. Leaving the battery inside is the usual cause for having the E04 when turning it on.
Hope this helps.
Mace1Mace
Dec 25, 2010 | RCA Video Cameras
CAN YOU DOWNLOAD TO A COMPUTER FROM THE RCA CC6363 CAMCORDER. THANKS
Hello :
Yes you can . You need to download the driver for your Camera first .
PLEASE DON'T FORGET TO RATE .
good luck .
Apr 09, 2010 | RCA CC6363 Camcorder
Camcorder won't record
Check the tape and make sure the record tab is still on the tape and has not been removed. If the record tab has been removed then use a new tape for recording as the unit will not record. This tap is usually on the lower left end of the back of the tape. When the tap is present it closes a record mode switch letting the system know the tape is able to bv recorded on..
Dec 27, 2009 | RCA CC6363 Camcorder
I am recieving error E04 "safeguard mode"
An excerpt from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
According to this, E04 denotes a problem with the recording media or the mechanical bits that deal with the tape. Hopefully trying another tape helps.
Mar 09, 2009 | JVC 580136 Camcorder
I keep getting the E02 message in safeguard mode, what can I do?
Dec 25, 2008 | RCA CC6263 Camcorder
Safe mode
Tell me what to do or do you have a manual for sale.
Dec 29, 2007 | RCA CC6363 Camcorder
Safegaurd mode
Unfortunately this is a repair issue. There are several failures that can occur, none of which will be resolved without service, that create this safeguard situation. Often the fpc cable which carries sensor information to the micro has been injured and that requires repair. Good luck, magic seadog
Aug 07, 2007 | JVC GR-D240 Mini DV Digital Camcorder
RCA CC6373 Camcorder Logo
Top RCA Video Cameras Experts
Lawrence Oravetz
ADMIN Canada
ADMIN Canada
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
