20 Most Recent RCA CC6373 Camcorder Questions & Answers
rca stuck in safe mode , how to get it out.
RCA CC6373... | Answered on Oct 13, 2012
Have you attempted to remove the battery and power from the camera? Usually when a camera is stuck in safe mode if you remove all power from the device and wait a while (I would say 15 minutes should do the trick) it will clear the safe mode and you should be off and running.
RCA CC6373... | Answered on Jun 27, 2011
http://www.google.co.nz/search?sourceid=chrome&ie=UTF-8&q=RCA+camcorder+model+%23+CC6363+is+stuck+in+safe+mode+fix
Hi at the above link, you will find a myriad of people with a problem exactly the same as yours, it is a real headache, with NO real, well DIY fix, sorry, it appears that RCA will repair it for a price, so maybe it would be simply best to bite the bullet, and take it to a professional RCA servicing center, but ONLY ask for a "Quote". Now when you get this information, then you can make up your mind as to what to do, repair or replace?
As an aside here, and it is mentioned in that link i give you above, that this problem is a "Known About Issue" and in some countries they have been made to repair this issue FREE of charge to customers...
I actually haven't come across this exact type of problem with this exact type of camcorder, however, in my shop, I have seen similar repairs etc, and they can cost upwards of $200.00, so make sure you always get that quote. Further, there are a few postulated "Fixes" in that site given too, you can not do any real harm in trying any or all of them, especially the one about cleaning the "Heads & tape transport path" as described, this may just work, as may the Battery Removal/Replacement ... so good luck.
Hi.
Safe mode will start when a fault gets detected by camcorder control board.
If there is no fault, and the safe mode was triggered because of a temporary problem, then the camcorder will reset simply by removing battery for one minute.
If the Safe mode does not clear after removing and putting back the battery, and you get an error code, then there is an internal fault.
In your case E02 is traction error. This often happens because of mechanical problems in the tape player/recorder drive unit inside the camcorder.
You can try tapping the side of the camcorder with you hand, with the tape inside. Try also playing with Play, Rew. and FF. buttons, in some case that will unlock an E02 error.
If that does not happen, then there is a mechanical failure. In that case the camcorder must be taken apart and repaired by a technician.
Best regards.
RCA CC6373... | Answered on Nov 22, 2009
need instruction manual
RCA CC6373... | Answered on Dec 11, 2008
Do you have a model number? I found a manual for the RCA Pro8, Pro807, from Voxx here: https://voxxintl.zendesk.com/hc/en-us/articles/225487888-Information-and-Owner-s-Manual-for-the-RCA-PRO8-Model-PRO807-Camcorder . The direct link to this manual appeared as https://sc.voxxintl.com/docs/common/PRO807/PRO807_OM.pdf in my browser history.
I hope this helps.
RCA Video... | Answered on Sep 09, 2018
Try Googling (RCA)(model)(manual) without parens.
RCA Video... | Answered on Mar 27, 2018
I am sorry to say that it appears you may have answered your own question, the "hundreds of hours" is the clue.
Consider the possibility that your camera is worn out.
Sorry.
RCA Video... | Answered on Dec 12, 2017
nice question....
RCA Video... | Answered on Nov 29, 2017
It appears to have a built-in USB connector, use that.
RCA Video... | Answered on Nov 10, 2017
I understand you have a problem. What is not clear from your description, however, is the actual nature of the problem. Please can you state it more clearly. Thank you.
RCA Video... | Answered on Jun 15, 2017
Won't say what ? Hello ? Goodbye ?
RCA Video... | Answered on Jun 09, 2017
You can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
RCA Video... | Answered on Jan 02, 2017
RCA CC6373 Camcorder Logo
19 questions posted
Top RCA Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
View Most Popular
RCA Video Cameras
  • RCA Video Cameras
Most Popular Question
rca 200x auto shot camcorder instruction
  • Video Cameras
