I have unplugged everything and even left it likevthat overnight. We havent watched tv on openview in over a week
SOURCE: RCA 27" TV Guide Plus
If you have the set off, and the cable plugged into the back of the set for a day or so, the guide plus should come back. It will sometimes take up to 48 hours. If it does not, there is a problem with the set and will require servicing. Good Luck
SOURCE: rca rcr860 remote manual code list
http://157.254.235.130/public/RCR860.pdf
http://157.254.235.130/public/RCR860_code_list.pdf
These are the sites for the manual and Code List
SOURCE: no channels on list
You have to search for the channels. Go to your setup menu, and go to setup, then select TV, then do auto channel search. It may or may not have to be set on tuner to get to the TV options.
SOURCE: TV screen went negative. Brand new TV
I would use the warranty for this problem. The part that need to be replaced can be somewhat expensive.
With the credit card statement, you can use that as a receipt.
SOURCE: PS3 + UPDATE = bad for me
Sounds like your stuck in a firmware update loop.
See what happens when you boot the PS3 with the hard drive out.
Do you still get the same menu on screen?
