SOURCE: Soap Dispenser Problem with Kenmore Elite Dishwasher
its possible to have a faulty dispenser, but i would look for other reasons first. Im a big powder user and proponent. powder just breaks down better in hot water.Have found that by using the tabs(whoch im sure the gel packs could give same issue) that they dont really fitting the dispenser as well they're a little tight to close the door and the spring action of the dispenser is sometimes not enough with te extra pressure from the tablets.also ck to make sure youre loading it correctly and nothing is blocking the water form spraying into the cup fully emptying it
SOURCE: kenmore elite he5 - error code F30
F 30 code can be reset by un plugging power cord for 5 minutes also pull out the detergent dispenser and reach all the way in to the back there is a small plastic flapper valve move it from side to side with your finger this will rest code f30 and save a tech visit..
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
SOURCE: kenmore front load washer is leaking water from soap
We had a similar problem with water coming out of the soap dispenser when the washer was run. I assumed that it was a problem with the water draining as everyone else posted here. I took off the front panel, got rid of the junk and drained it. Although this was great, it did not solve the original problem. It turns out that there was a sock stuck in between where the water comes out of the soap dispenser and in to the main compartment. Pulled it out with a needle nose plier and good to go. Thanks to everyone for their input here.
Testimonial: "good to go "
