Samsung SCX 4521F All-In-One Laser Printer Logo
Posted on Jul 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toner empty message
My samsung 4521F laser printer has been giving me a message low toner for quite sometime, it was still printing fine , but I figured I have the printer a year and maybe I should buy a new toner cartridge. I did I replaced it, my printer works fine but I am still getting a toner low message and now a toner empty message. My printer is used at home and does not get the use of an office printer.  help!
elig1000
Level 2:
  • Expert 112 Answers
  • Posted on Jul 30, 2009
elig1000
Expert
Level 2:
Answers
112
Questions
0
Helped
45117
Points
257
I would try to unplug the printer and leave off for a few minutes. and see if that resolves the problem.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Samsung toner empty
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
I will refilling in toner Samsung scx 4x21 printer but display is toner empty what to do sir
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder. When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
I will refil toner but message showing toner low. please solve my problem.
2helpful
The printer samsung scx-452f cannot print out fax in,it shown on screen as memory receive
you have received faxes, but they can't be print until you replace toner because probably you have TONER EMPTY message also on the display.
You can buy only fuse for toner cartridge (25mm, 250V/ 0,063A or 0,1A and maximum 0,125A)
When you pull out toner cartridge you will see the glass fuse on the front left side of the cartridge.
The new fuse will reset toner empty condition
pifonski
2helpful
Showing low toner message and prints half the page very faintly
indicates that the toner cartridge is becoming empty and needs replacement.
follow cartridge replacement procedure for this device.
to maybe get a few pages from the old cartridge.
remove it and give is a gentle shake from side to side. and then replace it.
this is not a fix but may give you a few more pages printing.
recommended to use samsung recommended replacement cartridge.
I hope this was helpful.
Samsung SCX-4521F All-In-One Laser Printer states there is a document jam and toner empty but no documents are jammed and the toner has ink....cannot find the paper sensor to check if its causing the...
hello try to do this
press #1934 and right arrow key disply appear ready tech press menu &left arrow key display new cartridge press enter button twice. then toner empty message is over do previous simulation for go normal condition.
paper senser is located at back side of the machine remove backside cover and see heater unit near the hot roller paper senser is located
5helpful
Toner empty after replacing new toner of samsung scx-4521f what to do to remove this message
press menu# 1934 then display tech mode
press left arrow key and enter twice
then its ok
to go normal display continue previous simulation.
1helpful
4answers
SCX-4521F All-In-One Laser Printer: toner empty after replacing new toner of samsung s...
Clear/reset the settings on the printer. Press in this order w/o pausing:
menu
193
start
If you do it correctly, the LED will say "Select Country, US", then you press "OK", then it will clear the settings and the error message should go away unless you have a dirty sensor or your toner is installed incorrectly.
Good luck-
Samung scx-4521f toner refil but still printing light on paper
Donot refill the toner. Use the genuine cartridge. If you use the refilled it may cause printer damage.
Not recieving only in memory
My good friend:
The only reason why your unit stops printin faxes is because the toner cartridge is nearly empty. Th e unit will then try to conserve the remaining toner for printing and copying. Follow this steps to program the unit to print all faxes, even with toner low:
When the toner cartridge is nearly empty, the machine shows
the “[Toner Empty]” message and continues printing except
incoming faxes. In this case, incoming faxes are saved in
memory.
However, you can set the machine to print incoming faxes, even
though print quality is not optimal.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button ( or ) until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button ( or ) to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Be blessed
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
