I have a LG washer WM2032HS that is extremely noisy when running - it used to be "whisper quiet" but now sounds like we're in the middle of a tornado! Ideas?
Re: LG washer WM2032HS that is extremely noisy now!
If the machine is noisey when spinning it means the seal at the back of the bowl has failed,Letting water past & into the bearings,It is a large job as the whole bowl assembly needs to come out to repair it,Sorry for the bad news,Kind Regards.
I descaled my kettle because it needed to be done (it was quiet before I descaled). However, it has become noisy since I descaled. Any suggestions, most welcome?
Have you tried descaling the kettle? When scale builds up over the whisper quiet element, it reduces the effectiveness, and the kettle becomes noisy. Try 1 tablespoon of citric acid, fill the kettle to the max line, boil the kettle then leave for 10 minutes. Rinse and repeat if necessary.
usuallly a pump motor asssembly is required.. most had a five year parts warranty and if out of warranty most assembly are 100-300 dollars for the part.
Try blowing out the motor housing with commpressed air through the cooling vents as it is running, if that dont quiet it down it may be the bearings are dry and need to be oiled, use 20w 3 in 1 oil in the blue container.
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Ok. So first things first. LG have a reputation with all their products. THEY ARE ALL BAD! If you remember GoldStar, they are now LG. GoldStar had horrible products. Now this is what LG has. The fact that the filters are cleaned and the units are serviced is an abosulte plus and will provide the units with extra longevity. Now are these drains are they used for water drainage. If so the upstairs units shouldn't need them unless there is some sort of rise in the drain pipe.
Now to the noise. It seems like there is something which is causing the fan to make a noise. It could be loose bearing or a piece of the fan which has broken away causing it to hit the inside of the unit. Since it is on both units, it would be a generic problem with this series and unfortunately is what you are stuck with now.
To combat this problem, I would: ring LG and the company who installed them and demand that they be repaired and have a warranty on the repairs. Just a heads up, LG are really bad to contact should you have a complaint, so keep persisting that they be repaired free of charge since that they are still under warranty.
If you are not happy with LG or your installers response, I would remove the units and have another brand put in. I recommend Mitsubishi Heavy Industries and Panasonic. Both units are whisper quiet. In fact they are quieter that the LG.
Oh and that only reason why LG boast about their "whisper quiet-ness" is because that is probably the only good going for them - and thats' not even right!
I hope that I have helped you in some way. Good Luck! Mat
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
