Most common causes of noisy spin are something has found its way between the drum and its casing or the heater has come adrift from its fixing and is rubbing on the drum
the bearings have gone, if the drum can be split, remove complete drum and replace bearings, if you dont think its something you can do, dont attempt it, but to be honest, its realitivly easy
It is more than likely not level... put a level on the top north to south and east to west... adjust the legs by turning them to lower or higher the legs
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
I bought the frigidaire affinity washer. It was quiet until it began the spin cycle, then it sounded like a jet taking off and began to bounce. Come to find out we set it up improperly. You must remove all shipping bolts on the back of the machine and make sure it is level. Ta Da!! it now runs perfectly quiet with little vibration.
due to weight and normal motion during wash/spin a very sturdy floor is necessary under front loads also some floors are a little slick and sliding may occur ck for weak floor and maybe some kind ok rough cushion under feet to reduce sliding also if on pedistals even more vibration may occur be sure all screws in pedistal are secure usually 4 from top onto bottom of washer also adj legs to lower unit as close to floor as possible and tighten lock nuts
make sure the washer is level.there's locking nut for each legs sometimes thy become loose and the unit becomes unlevelled after a while. Level the unit side to side and front to back and relock the nuts by tightning it against the bottom frame. If thats not the problem,run it on spin only with no load and see if it would do the same if it does'nt then your problem could just be improper loading. make sure you have enough load to cover the drum when it spins.Other wise you may have shock/spring problem but very unlikely
