SOURCE: copying vhs to dvd
you could google for macrovision scart leads that will do the job .
of transfering the vhs tapes to dvd .
riz.
SOURCE: copying vhs to dvd using samsung vr357 ??
do a search for the dp5000 unit on line its cost about $119.00 $12.00 shipping i have one and it works flawles. it will remove the copy guard but remember this should not be abused if you know what i mean it works both on vhs and dvd you can copy any thing. you will need another cheap player to do this out from the player into the DP 5000 into the recorder I have been coping all my vhs to dvd and the nice think is you can watch any channel on tv while runing in the background this is only available when going from vhs to dvd when dvd to dvd you have to watch it or put it on timer you cannot watch another channel. i bought a samsung dvd vhs player from sams club for 79.00 the dp 5000 for $119 and i say the investment was worth it . i have a dvd player in my car and to take originals with me would be a disaster as some time i get sloppy with them
SOURCE: Copy VHS whith copy protection to DVD
hello jordannoanno
this is true the macrovision will stop you copying the copy right tape /dvd .
this can be over come by removing the macrovision >
if you email me i will tell you how to go about this .
riz.
SOURCE: Error code E 4 54040990
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Dafid
SOURCE: burn errors cant get drive to write
It looks like from error codes that yoi may have a hardware error, or a disk format problem, if this is only burning problem you have on pc and it worked before, then uninstall and reinstall Nero, info gathered from here,
http://www.isobuster.com/help.php?help=305
sense code 5 ASC 2c= 5 / 2C / 00 COMMAND SEQUENCE ERROR
5ASC2700=5 / 27 / 00 WRITE PROTECTED
Please give good rating if this helps you or points you in right direction, thanks
