Yes! You can select to copy from VHS to DVD or DVD to VHS, set the VHS tape ready to play and press pause, then put a blank recordable DVD disk in and then select copy, the options for VHS to DVD or DVD to VHS can be selected and then it will copy, when the tape gets to the end it will turn off itself, if you want to stop earlier you will have to stop it! Hope this helps.
SOURCE: DVD Player does not work
General
Problems
Player won’t work (locks up)
Try unplugging the AC power cord and plugging it back in.
Reset the DVD/VCR: on the front of the unit, press and hold the STANDBY/ON
button while you press and hold the STOP button—wait at least 3 seconds
before
you release both of the buttons. You’ll need to set up your menu preferences
because this Reset Procedure returns the DVD/VCR’s menus to the
factory default settings and also erases the
contents of the Disc Library.
SOURCE: recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
SOURCE: go video dvd recorder vhs combo vr3845 - won't read discs - says unknown disc
FIRST UNPLUG THE UNIT FROM POWER !!!!! The problem is dirt/dust/****/crud/stuff on the tiny, little ***** laser lens. Remove the case screws ( 2 on each side, some in the back) with a correct size driver. The cover must be pulled open at the bottom, side to side a tiny bit ( use a hand on each side) to allow the cover to lift up at the rear, it must come up quite a bit as if it is hinged at the front and THEN pulled back out of the front panel. Set the cover to the side. The DVD reader/Burner is covered with a small black cover, it is held on with two TINY screws, STOP!!!! Get yourself the CORRECT size driver at Fry's or Radio Shack, DO NOT get cheap here!!! Remove the two screws and find the two plastic grip tabs, push them to release and lift the cover. There is the laser! It is a tiny blue lens about the same diameter as the tiny screws. find a very, very well washed CLEAN 100% cotton T-shirt. The softer the better, get 70% or higher rubbing alcohol, pull the fabric over the tip of the finger and wet with the alcohol. VERY GENTLY wipe the lens 4 to 5 wipes and the 3 wipes with a dry spot. That should clean the lens. USE NOTHING ELSE!!!!!! The lens tracks back and forth on two tiny bars. The stuff I use is WD-40 wet on a Q-tip swab. Go to a safe place to spray the WD-40 on the Q-tip. The lube should drip. With the Q-tip apply the lube to the tiny bars at the ponts of rider contacts and wipe the bars too. Put the top of the burner back> BE CAREFUL!! Use a magnet driver and then repower and try to read a known good dvd. You will have to do this more in the future, you understand, dist dirt etc in the air. Put the top back on. Enjoy.
SOURCE: How to record a VHS tape to a DVD disc
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
SOURCE: LG RC389H. Can't record vhs to dvd
Put both your vhs and blank dvd into the player.
Go into VHS mode and press "Home" menu button.
Scroll across to "Easy Menu" and select "Dubbing".
Make sure you are at the place on your VHS where you want to record from and select the "Dubbing" button.
Press the Stop button to finish transfering.
When it has done recording file information, press eject once and select to finalize the disc.
And that's it!
