SOURCE: My Bernette Deco 600 is not picking up the bobbin thread
At the very worst you may need to retime the machine if you have already checked that the needle is in the correct way round and is a good one, I can attach timing instructions if you email me [email protected]
SOURCE: bernette 90E
Our Bernette E90 timing was off due to a jam (design flaw I think)...Instructions on how we fixed it.
1. To correct timing, tip over machine and unscrew inspection plate.
2. Find the gear and unscrew the 2 grub screws so the gear is free from the shaft
3. Turn the main sewing machine handle to manually get the hook (pointed piece) of the housing (see arrow) to be directly behind the needle
4. Hold it the tightly, and turn the handle again, the needle should be able to go up and down while holding the hook in position.
5. When the needle is at it lowest and starting to move back up and the hook is directly behind tip the machine over and tighten the 2 grub screws on the gear underneath.
6. Replace inspection cover and you’re done
SOURCE: Bernette 56, can't wind the bobbin thread, the
check the bobbin tension for the thread size you are using as it requires adjustment for different threads
