Televison & Video Logo
M
Michael Shaw Posted on Dec 09, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
IHTB158 -have to hook audio cables up to cable box to get sound?? When I try to watch a movie off my firestick which is hooked up to the tv no sound. Tried hooking up firestick to cable box.no luck??
Phil Whisenant
Level 2:
Habit-Forming:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 163 Answers
  • Posted on Dec 09, 2017
Phil Whisenant
Expert
Level 2:
Habit-Forming:
Cheetah:
Answers
163
Questions
14
Helped
46118
Points
361
You will have to use HDMI to receive sound.
I’m happy to help further over the phone at https://www.6ya.com/expert/phillip_293d34ebcf028794
Testimonial: "I have an HDMI cable from tv to the cable box??"
2answers
I have an RCA rear Projection TV model # p60812BL manufactured in 1998, no sound is coming from the tv when watching cable TV via a digital box. When the mute button is pressed and unpressed you can hear...
Tries tv and cable box unplug,replug it back like about an hour.For the tv resetting itself and the cable box to upgraded it softwares.Go into the tv menu go to Audio SETUP.Go down to audio ressetting,these steps should solved ur problems,but not call ur cable companny replaced the reciever box,it have problems.
2answers
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Best way to hook up all my componets
The best way to use the Denon and get your money's worth is to connect all devices to the Denon using HDMI connects if possible, if you use HDMI make sure you assign the audio if needed.
HDMI from Denon to TV. the Denon will upconvert all signals to HDMI to the TV
2helpful
2answers
How do I hook the tv up to the speakers?
we had to hook sound cables from DVD player into digital cable box, not tv and now surround works in tv mode as well as dvd.
NO SOUND FOR TV BUT I HAVE SOUND ON DVD
the bose has to be hooked up to the cable box output and video 1 on the bose. This is the only way it will work
Audio from tv
It sounds like you have the red,white rca cables hooked from the back of the tv to the red,white input on the stereo or the same connection from you hd sat box or hd cablebox. In order to get the same sound quality from tv service as you do on dvd is to run a fiber optic cable or digital coax audio cable from you hd sat box or hd cablebox to your stereo which means no red,white rca cables at all, take them out. Also once you do that you must be on a hd channel to get equal sound quality of a dvd movie. I know on some hd cable or hd sat boxes you have to go in and set them up to dolby digital as well after you hook it up the way I was explaining. Try this and I hope this is helpful.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
How to hook up my dvd player to my cable box
Richard,
I would have to guess that you are hooking up a DVD recorder?
If you are then you take the video and audio cables out of the cable box and hook them in to the DVD R input plugs. The output wires go to the TV video/ audio in. Its just like hooking up a VCR.
Now if you are trying to hook the DVD player up to watch movies then you have to hook up the audio/video cables up from the DVD to the back of the TV into your Video 1/2 input. If you have the Component wires you hook them up the same way.
Now if your TV only has the one set of plugs (video/audio) then goto your local Audio/Video store and pick up the A/V cables that have the "Y" or "T" plug on one end.
I hope this helps you.
1helpful
How do I get my tv to play through the surround sound
If you have direct cable into the television, you will need to use an audio output if available on the back of your set into your HT system.
If you are using cable w/ a cable box you have two options. You can still connect everything directly into the TV then reroute the audio to the HT system... or, you could hook only video to the TV and audio from the cable box to the HT system. Really up to you.
3helpful
2answers
Sony surround sound hookup
In short, the answer is: Hook up all three to each other. I have a Samsung DLP HDTV, and I was trying to hook up a Sony DAV-HDX500 home-theater system and a Comcast HD set-top box, but I found that the Sony user guide is helpful only for setting up the speakers. Most of what it had to say about HDMI and getting the TV sound or cable sound to go through the speaker system was wrong (or, at least, it didn't work for me). So, here's what I did. I connected Component video cables (Y/Pb/Pr out) from the Cable box to the TV (Y/Pb/Pr in), audio cables from the Cable box (audio out) to the Sony system ("SAT/Cable" audio in), and an HDMI cable from the Sony system (HDMI out) to the TV (HDMI in). This allows me to 1) watch DVDs with surround sound through the TV's HDMI source (when the "DVD" format is selected on the Sony system), 2) watch cable with surround sound through the TV's Component source (when the "SAT/Cable" format is selected on the Sony system), and 3) watch cable WITHOUT the surround sound, as I did before I ever had the Sony system. One item of note: When watching a non-HD channel with the surrond sound on, the audio is slightly out of synch with the video; thankfully, there's no such problem on HD channels. Anyway, I hope this helps. It drove me crazy for two days straight!
Hooking up cable through ht-x50
You need an Optical Audio Cable. Hook one end to the HD Cable Box and the other to your Surround Sound System. If you dont have an Optical Cable to your Cable Box, then try using the usual audio cables. But, I have HD and it worked with the Optical Audio Cable.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
