SOURCE: Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
SOURCE: Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
SOURCE: my ariston washing machine door not locking
I recommend replacing the door latch. It is a fairly common problem. You can get one at repairclinic.com or partselect.com
SOURCE: HOTPOINT WF541 WASHING MACHINE DOOR CATCH
Check this out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Gallery washing machine door latch stuck in lock p...
I have the same problem with my Gallery. I can not open it at all. I have tried unpluging it and putting it through another cycle to see if it will open. No such luck. Any suggestions?
