20 Most Recent LG WD-12126RD Front Load Washer / Dryer Questions & Answers
I would clean out the lint as thoroughly as possible. The symptoms seem to point to a thermal cutout switch activating. Usually the lint will cause the heat to build up to the point to where the unit shuts down for safety reasons. Try a deep and thorough cleaning first.
LG WD-12126RD... | Answered on Oct 01, 2018
Start with power. Try using a different outlet or extension cord to eliminate your outlet as a problem. examine your cord, look at the prongs to see any melting. if all ok next step is to look at power coming in to control.
I’m happy to assist further over the phone at https://www.6ya.com/expert/donald_a8261495ff0777e2
LG WD-12126RD... | Answered on Mar 07, 2016
if it is like my dishwasher the oe code means the unit is over filled with water. My dishwasher had a major fault that blew up a circuit board and had a faulty front assembly. Still in repair shop waiting for parts.. I would deduct that the washing machine is not emptying water so I think a water pump could be failing. My dishwasher was not activating the washer motor and came up with the same code but..
LG WD-12126RD... | Answered on Apr 07, 2015
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
LG WD-12126RD... | Answered on Jan 31, 2015
It could be the heater element if the machine is operational but not heating, or check the function buttons mine has a cool button that doesnt dry it just airs out laundry.
LG WD-12126RD... | Answered on Jul 28, 2014
I strongly suggest you start by checking the drain filter and motor following the guidance notes below ;-0)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Look for a temperature sensor on the motor, usually two wires going into a wrap of varnished paper, with the sensor inside. Run the unit with the sensor away from the motor, but check the motor by safely touching it to see if it is overheating. If the sensor is tripping too early, see about replacing it. It won't be an available part, I expect, but can be found online by Googling the numbers on it.
The motor could also be overheating because some bearing is bad, too, check the unit for freedom.
LG WD-12126RD... | Answered on Nov 26, 2013
need fix the board,
LG WD-12126RD... | Answered on Oct 15, 2012
(common problem so pre-typed!)
Many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
LG WD-12126RD... | Answered on Sep 19, 2011
LG WD-12126RD Front Load Washer / Dryer Logo
70 questions posted
Top LG Washing Machines Experts
Marvin
Marvin
jimorris77
Paul
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
LG Washing Machines
  • LG Washing Machines
Most Popular Question
lg wd12331ad stops different stages
  • Washing Machines
