whatever problem you are having with brivis buffalo, the first thing you need to try is RESET. This is how you reset.
1. turn off your heater from wall switch for at-leat 5 sec
2. turn on your wall switch for 5 sec
3. repeat step 1 and 2 for atleast 3 times within 60 sec
my brivis buffalo 20 was keep turning off after 30 min. RESET fixed my problem
Shorted circuit board components. Contact any service technician or the authorized service centre for LG, to confirm. Troubleshooting to plasma TVs is really a skilled work. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Gas or Ele.? If its gas get a dollar bill an clean the flame sensor, and or it may need to be replaced. If the unit dosent sense the flame within 30 sec. or so it will shut down the gas valve. That would be my first check
Okay, to program a key you will need two keys that are already programmed, insert one key ignition turned on and engine off, remove the key and within 10 sec insert the second key and turn ignition on with engine off, remove that key and within 10 sec insert the key to be programed. you will need to do a 30 min.relearn with only one key,you will turn ignition on with engine off and wait about 10 min until light goes out then remove the key and repeat this step when light goes out repeat step one more time then use key to start car, computer has learned all info. you will now turn off engine, insert programmed key turn key on engine off then remove the key and insert key to be programed within 10 sec.all done good day.
these particular tvs are very sensitive to voltage changes spikes etc.first turn off main power switch wait at least 30 sec if standby come on wait another 30 then turn off main power again and unplug tv for 1 min then plug in turn on main switch wait 30 sec then turn on tv with remote resets system.then buy a ups and always wait at least 30 min after turning tv off to turn back on if not causes power failure and after each press of power button wait 30 seconds before trying again lmk good luck
