20 Most Recent
Sony Bravia KDL-42V4100 42 in. LCD TV Questions & Answers
Have a 6 month
If you wish to get some details; visit the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations
. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (
Exclude the model number), in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts
TV will not power on.
Check all fuses. If you have power going into the power supply board..but none coming out of it...I think you have found your problem. Get a new power supply board.
Sony Bravia 42" Horizontal Lines
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
How do I brighten a Bravia KDL-42V4100
Sounds like back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Need code to make universal remote work on sony tv
hello sir,
i m having problem please n please solve it........
i hv recently buyed a new LCD Sony Bravia KLV32BX300 ON 2nd FEB. 2011 and im having Airtel digital tv HD alos and i have connected LCD and DTH with HDMI cable ok....then problem is that how to make my DTH universal remort to operate my tv remort sensor..how to sync..my sony remor with dth remort..and i have try my best but im faild i know my dth remort code that is [OK+2] HOLD THESE buttons atleast 3 sec. ...............tell me what was my sony bravia pairing code.........please please nnnn please
