SOURCE: Red bar across top of screen??
I had the same horizontal, solid red bar along the top of the tv screen. I have an older analog Philips Magnavox TP2785C221. It just started all of a sudden. It was on every channel. However, the bar did not appear on the other input channels (e.g., AV1, AV2). So this meant that the red bar was only occurring on the antenna input. I unplugged my cable decoder box and restarted it. The red bar went away and that seemed to solve the problem for now.
SOURCE: acer 7720 will not boot
Do you want to try and see if a 'Linux LiveCD' boots? This is the way I test if the computer works. You burn this CD to a disk, and then boot off of it when you're computer starts. I will not modify anything on your computer as long as you go to 'Try Ubuntu with out installing'
http://www.ubuntu.com/getubuntu/download
Don't worry, I'm not trying to get you to install anything, just see if it boots into the 'live environment' (means you are running it off of the cd) If this works, that means that it is only your windows installation is messed up, and a reinstallation of windows should work fine with a Windows install CD NOT the recovery cd.
SOURCE: 7720 will not boot
off course it is repairable dont worry look try to install OS thru the following procedure to factory default state
Acer: When you first turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
if it installs the OS ok then fine if not
pls consider changing RAM take out from beneath the laptop open the cover all screws and take out the L shaped panel then u will see the RAM in front with 2 chips one uper and one lower side try to take out both and then re fit only one in the upper slot and then try to install if hangs again , then try the 2nd chip in the first slot and repeat the procedure if it works ok only try both chips one by one if it resolves ur issue and u find the faulty one replace it with new one with sam specs
in the last case if ur system still hangs then my friend ur hard disk is giving u hard time it needs replacement
when a system boots after bios loading all that is trf from Hdisk to RAM and then OS is loaded if one have problem system will hang or freeze try these solutions and then tell me the results
pls go step by step
and pls rate me fixya if i fixed ur problem
kindly let me know abt it and tell me in detail the messages u get and the system behaviour
SOURCE: Dell latitude d600 screen goes black during boot
ok after you have booted in safe mode do a restore to a date just before the last day it worked properly and try that restore is found here
start/programs/accessories/system tools/system restore
hope this helps
SOURCE: When I boot into Windows Vista Premium nothing on screen
In Safe Mode, your monitor will not be listed as it is using a generic device driver for basic display. Go into your video settings and reset it to the lowest resolution available. Reboot the computer into Vista again and your display should be working. If you check Device Manager now, you should see your monitor listed. If it isn't, you will need to load the Vista drivers for it. You can then modify your display settings to suit your preferences.
