20 Most Recent Pentax Optio S4i Digital Camera Questions & Answers
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use ACDSee or any other photo cataloging program.
Pentax Optio S4i... | Answered on Aug 31, 2012
Try the procedures in this tip.
You don't need to install anything.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
You don't need any special software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
You don't need a driver.
Consider NOT connecting your camera to your wife's computer.
The best way to download pictures from your camera to a computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Pentax Optio S4i... | Answered on Aug 30, 2011
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa ( http://picasa.google.com ).
Pentax Optio S4i... | Answered on Aug 10, 2011
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Pentax Optio S4i... | Answered on Jul 05, 2011
Hi bacayemilita,
I think you meant that you need to transfer your images from your camera's built in storage to your external memory card.
Please follow the below steps :-
  1. Connect you camera to your computer via the USB cable and then switch your camera on.
  2. Once you switch the camera on you will find an option for mass storage mode , please select that option.
  3. Remember to remove the memory card from your camera while you do the above step.
  4. Once you select the mass storage mode , you will find a removable drive being displayed in my computer , in this drive you will find all your images, so all you need to do is copy them all to your hard disk drive.
  5. Now if you want to copy these images to your memory card , you can either do it via connecting your memory card to a card reader and copy the images from your hard disk onto it Or you can connect the camera while keeping the memory card in , and you will find another removable drive for memory card , when you select mass storage mode.
  6. When you find the drive , just simply copy the contents from your hard disk to your memory card's removable drive.
Hope this helps ..:) Your feed back would be greatly appreciated.
Pentax Optio S4i... | Answered on Jun 26, 2011
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Pentax Optio S4i... | Answered on May 03, 2011
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Pentax Optio S4i... | Answered on Apr 29, 2011
just go to the brands website and look for updated version of your software.
or download it here:
http://www.pentaximaging.com/files/scms_docs/usbsw20.exe
Pentax Optio S4i... | Answered on Dec 20, 2010
Have you tried formatting the card in the camera first?
Pentax Optio S4i... | Answered on Nov 26, 2010
I just fixed a friends Pentax Optio S4i.
You want to extract this file.
File name : O4IE101W.EXE
Format your SD card in my computer. Open the O4IE101W.EXE on your desktop. It makes the file fwdc124p.bin. Put the fwdc124p.bin on the SD card.
I did save this file on the flash card.
Then I fully charged the battery (I got this from the Pentax site)
I opened the "secret menu" by pressing the MENU-FLASH and the POWER button at the same time.
Once menu opened, I pressed the FOCUS twice then (FLOWER, MOUNTAIN, MF) symbol twice after this two toggles to the right with the OK button.
Then press the MENU button once again.
So the menu screen open now.
Down toggle of the OK button, go to ROM UPDATE then go down to "SYSTEM INITIAL" and press OK. Press another OK to re-initialize your camera.
Once this has been done, turn your camera off.
Turn camera on again opening your camera with the MENU+Power ON procedure...finally this should be posting "Complete" after the "Loading"
When it shows Complete, turn camera off.
You are finished and your camera should be ready to work again.
At least this is how I fixed my friends A90 error message.
The firm ware is here:
http://www.pentaximaging.com/support/manuals-and-literature/
navigate to your camera
Pentax Optio S4i... | Answered on Jul 26, 2010
Pentax Optio S4i Digital Camera Logo
Popular Tags
43 questions posted
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
View Most Popular
Optio Pentax
  • Optio Pentax
Most Popular Question
find installation software pantax optio
  • Cameras
