? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Feb 8, 2012 - 7 posts - 3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house.
Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012 Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012 More results from www.tomsguide.com
Missing: 32dv22u
Sharp LED/LCD EEP cleared Step
Remove Mains Plug
Press On/Off Switch from LED/LCD Panel
Press Ch Down & Input Switch together and plug in mains cord
LED/LCD will start
5
"K" will appier on Screen
6
Press Ch Down & Vol Down from LED/LED Panel
7
1/9 Page will appier on Screen
8
Go to 9/10 page by pressing Up & Down arrow of remote
9
Select EEP Cleared
10
Press ok button from remote
11
On Screen dispay EEP running
12
Remove Mains Plug after complete EEP Run
13
Restart LED/LCD
This problems very common on Sharp Tv.Do ur tv LED power light turn on solid first.Few mins,than LED,OPC flahes.Power LED,OPC flashes,push power button again,do this at leat 5 or 6 times somtimes the backlight will come back on and work.The power LED,OPC light flashes,turn off/on more than 5 or 6 times don't work.Ur Tuner signal board is dead,must replaced.
First turn on power light stable at all?Power and OPC lights well flash,but push on/off power button do this couple times after the Power and OPC flashes well backlight come back on well work.This problem very common is Sharp tv.
Ur power light stable green first turn on?Then awhile click,POWER and OPC flashes.Tries on/off couple time,will work.Not then ur backlight video board is dead.
I had a similar problem. Fleeting video, then audio only for few seconds and then nothing except the green power LED blinking on and off. I changed the power inverter board, backlight inverter boards and power supply board but still the problem is not gone.
