20 Most Recent Sharp LC-C5255U 52 in. LCD TV Questions & Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sharp LC-C5255U... | Answered on Feb 07, 2017
Main digital board fault. Check and replace it. Contact any service technician. If you wish to get more details visit the site linked here. Usually a main board replacement might have to be followed by a firmware update. http://electronicshelponline.blogspot.com/ Search the site by type in the brand name of your device in the search box at the top right of the display window to get gathered all the related posts.
I just repaired this LCD tv exact same model.
symptoms- when the tv turns on, all I get is a black screen with blinking green light. No other error codes. It was crazy frustrating trouble shooting this. I measured the transformers on the master and slave inverter board with a multi meter. The resistance should be 1.31 k ohms. All but one measured within the specs except one. I get an OL reading. I took a chance to order this part on eBay for 13 dollars. After soldering it, the resistance for all of the transformers were back to specs. The tv powered on and stayed on. Works good as new. If anyone has the this similar issue I would advice testing the mini transformers on your master and slave inverter board. My email is normanw1@yahoo.com for help.
lcc5255u aquos fixed
lcc5255u aquos resolved
Sharp LC-C5255U... | Answered on Oct 18, 2014
If you do a factory initialization, nothing wrong could happen, except with its tuning settings. All the setting in the memory will be cleared, and the set will work as if it has been bought new. You should have to re-tune it and do all personalized settings again. That's all. In my view, for this case, doing a factory initialization will be better. If you do not get audio even after factory initialization, you should have to check its mother board's audio processor section circuit for the fault. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Sharp LC-C5255U... | Answered on Dec 26, 2013
LCD PANEL PT#: LK520D3LW10Z1 $1903.54 THRU Encompass http://www.encompassparts.com/item/8052257/Sharp/LK520D3LW10Z1/52%22_Panel_Module
may want to replace TV
Sharp LC-C5255U... | Answered on Nov 30, 2013
The it's possible .. But the cost will exceed the tv's value
If you need further help, reach me via phone at https://www.6ya.com/expert/tommy_ada038f5bd21609b
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom (look for discoloration of the circuit board around the base of the capacitor) need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the unit will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and/or inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are SURE it's only doing supply output ripple filtering,
and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
Backlight related video here:
http://www.youtube.com/watch?v=6XoF6QZ1dmw&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors, amplifiers, computer power supplies and motherboards, and other electronic equipment.
The parts are cheap, and skill required is minimal.
A great parts source is Digi-Key, and you can order the parts online at www.digikey.com
They typically cost under a dollar a piece plus a flat shipping rate.
The parts usually arrive one business day later.
If you watch the third video, you will see that even someone with no soldering experience can perform these repairs as demonstrated by the woman in the video.
Sharp LC-C5255U... | Answered on Oct 11, 2012
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out power transistor and zener diode...if otherwise, Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
Sharp LC-C5255U... | Answered on Jun 23, 2011
It can be the power supply, backlight inverter board, etc.
First thing to inspect will be the caps in the power supply module, look for caps with leaking/bulging tops, check the DC output voltages, ect.
Learn more about troubleshooting here:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Sharp LC-C5255U... | Answered on Dec 11, 2010
At 8:30 AM CST call 800-237-4277 to be walked through an INIT. That is a factory reset that might correct this issue.
Sharp LC-C5255U... | Answered on May 07, 2010
Sorry to hear that you are having problems with your Sharp TV.
Unfortunately, there is no "reset" of some type on this kind of TVs. This issue is caused by an error in the power supply. Perhaps a semiconductor was damaged. You may want to unplug the TV for a while, (Let's say 5 to 30 minutes) and plug it back. It may work after that, but definitely the TV needs service.
Replacing the power supply is the right solution. Check the warranty information, perhaps the manufacturer can assist you.
Sharp LC-C5255U... | Answered on Nov 05, 2009
change aspect
Sharp LC-C5255U... | Answered on Jun 07, 2009
Sharp LC-C5255U 52 in. LCD TV Logo
27 questions posted
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
LC Sharp
  • LC Sharp
Most Popular Question
light steady no piocture no sound
  • Televison & Video
