Troubleshooting & Support
Hot Topics:
- input signal
- external...
- size picture
- view mode
- parts
- picture white...
- channel
- sound
- compatible...
- not compatible...
- input label
- tv
- troubleshooting
- connect pc
- failed receive...
- tv stand...
- tv uverse...
- change view...
- manual
- channel scan
- speaker
- sharp aquos
- screen grey...
- service menu
- turns
- turns off
- LCD
- sound mute
- sound mute off
- power light...
- View All »
Problems & Solutions
Power light comes on but nothing on the screen.I
hi, Is there is sound on your tv. Is there is any light in the screen. If not, then Backlight inverter is faulty. All lcd tv have backlight...
We have a 52" Aquos
Go into the user menu and set the default to full. If this does not correct your issue, then take it to a service center. You are still...
Hi have a Neoniq 32cm flat screen, and I can't...
the first thing you do is to set your tv unit into TV mode push the menu button on your tv or at the remote controller. then try to put into...
Set is about 2 years old. Powered up and heard a
U have a soldering iron,desoldering pump or desoldering braids,solders.U understand basic electronic and can u do basic soldering?Yes,take...
Failed to receive broadcast E202 Sharp
What do you mean exactly when you say "failed to receive broadcast"? Does it not get a signal of any sort? What about from DVDs,...
thethe tv will not come on and power and theopc is
Ok This is how to troubleshoot the TV, there are lights on the front and you are mainly concerned with two of these lights (the power light...
Sharp Aquos LC-26D4U sound problem
See # 7. Same Sound issue. Sharp Tech Support tried to refer me to a service company for out of Warranty service (which I would have to pay...
I bought the Sharp TV LC-32D43U in 2007. Now it
Well for a start, they are NOT all the same models, also. a certain percentage, are expected to, and do fail. You see for a good repair,...
No sound
you can try doing it again
When I turn my 32
is it the same when using dvd?
Sharp Aqueous 37" LCD TV
From the information you have provided failed capacitors in the power supply is likely causing the problem. The safety circuitry shuts the...
I want to hook my laptop what video input should I
LC-37GD6U has DVI-I input, use VGA to DVI-A cable to connect your PC to the TV.
i have a sharp-aquos flat screen tv
Power supply board it dead.Replaced the power supply board should solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power...
sharp aquos lc37hv4u tv stays in standby mode,
One of ur fuses has gone bad and u must call Sharp Co.
how do i reboot my sharp dolby digital tv?
unplug set press and hold down valome and channel down and hold them while pluging in set will come on with k on screen us your remote and...
See all Sharp Aquos LC-37GD6U 37 in. HDTV LCD Television Solutions
Unsolved Problems
SHARP AQUOS 22"
SHARP AQUOS 22"
burnt wii menu on tv scren
Burnt Wwii screen on Tv
need code for Sharp Aquos LC-37GD6U 37 in. HDTV...
I have a new uverse remote and need the Sharp Aquos code number to set it up.
sharp LC-37SH12U TV can't change resolutio...
appears to have burnt areas on screen, moreso as it heats up. Can not see streaming messages on bottom of picture and...
Haier HDTV Channel Search on this TV only gives...
I bought this TV thinking all I needed to do was plug it in, do a channel search and the TV would pull in local...
cheapest way to fix the sound on my sharp aquos tv
my tv has no sound out of no where, the warranty is up.
my tv says Failed to receive broadcast, but when i
my tv says Failed to receive broadcast, but when i hook mp pc up on input 4 it works fine but the cable does not work on...
See all Sharp Aquos LC-37GD6U 37 in. HDTV LCD Television Problems
Upload a manual for Sharp Aquos LC-37GD6U 37 in. HDTV LCD Television
Specifications
TopKey Features
Full Product Name:Sharp Aquos LC-37GD6U 37 in. HDTV LCD Television
Screen Size:37 inch
Digital TV Standard:HDTV
Flat Panel Type:LCD
Display Resolution:1366 x 768 pixels
Display Capabilities
Aspect Ratio:16:9
Aspect Ratio:4:3 Enhanced
Built-in Tuner:NTSC
Built-in Tuner:ATSC
Display Format:720p (HDTV)
Remote Control
Remote Control:Standard
Image Quality
Contrast Ratio:800:1
Brightness:450 cd/m²
Viewing Angle:170
Technical Features
Parental Control:V-Chip
Connectors
Headphone Jack:With Headphone Jack
Rear Input Connectors:S-Video x 1
Rear Input Connectors:Component x 2
Rear Input Connectors:Composite x 3
Rear Input Connectors:DVI x 1
Rear Input Connectors:Audio (RCA) x 3
Rear Input Connectors:HDMI x 1
Rear Output Connectors:Audio (RCA) x 1
Rear Output Connectors:S-Video x 1
Memory Card Slot:PC Card
Memory Card Slot:PC Card Type II
Speakers
Number of Speakers:2 Speakers
Speaker Power:2 x 10 Watt
Dimensions
Depth:4 in.
Height:21.58 in.
Width:36.11 in.
Weight:40.8 lb.
Warranty
Overall Warranty:1 Year
What's your problem?
Fix-O-Meter
111,967
111,967 people have viewed this product
- 488 people asked about this product.
- 166 people found solutions for this product.
- 8 people have added this product.
How to fix...
Polaroid...
Programming...
