SOURCE: hi, i have epson stylus PHOTO 1410. now i have
I have epson photo 1410
when I start the printer on the print head is not moving and the bottons flashing red lights
SOURCE: My printer tx110 series has a general error it
If your printer jams frequently, you may be loading too much paper. This
can also occur if you’ve had jams in the past and have a piece of
debris still stuck in the printer.
Use a flashlight to examine the
entire mechanism to ensure no paper is still inside. This can also
happen if an internal gear is damaged. You will often notice one side
being fed faster than the other.
This could me the printer is physically
damaged and needs to be replaced or repaired. You may need a professional help and send it out for repair.
Let me know for any clarifications.
SOURCE: Remove any foreign objects from
Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes, turn the printer back on.
SOURCE: my epson stylus t13 have
Hello there,
This is called a false paper jam. normally, a reset is required for this.
Hold the power button for 30 seconds and this should prompt a shut down.
next, make sure that the rollers are clean inside. use a lint free sloth and some distilled water. Dampen the cloth (Q-tips works fine too, please do not use cotton) and rub the rollers.
Then as it dires up. turn the printer on and do a test page.
Please don't forget to leave a feedback and testimony if it works.
SOURCE: my printer Epson t13 has
do you have a ciss t13 printer?.. coz if you have , then the problem is in your hose installation is short, if its not then your michanichal gear is broke,.. you have to bring it to its service center
