Epson R265 - both red lights flashing fast, and simultaneously
My Epson r265 chewed up one sheet of paper. I removed both bits, but when restarted the two red lights flash fast, simultaneously.
As far as I can see there is no more paper jammed inside.
Re: Epson R265 - both red lights flashing fast, and...
When your Epson printer's print head is clogged , then the red light for your ink and paper out is blinking. In this movement, the printer print head is blocked due to foreign objects or jammed paper.
Paper has different thicknesses called Mils. Make sure you are using the correct paper for your printer. Paper that is thinner than is intended for your printer may sometimes cause it to take multiplesheets.
It means that the ink counter needs resetting and the waste inkpad changing/cleaned. The Epson website will give you the address of a local service centre.
Before paying out for that you could see if the SSC Service Utility would work for you although the R265 is not specifically listed as supported it is similar to the R270 which is.
The free download is available here
http://www.ssclg.com/epsone.shtml
I have problem with r265 Epson. I installed new ink cartridge from epson but the printer could not recognize it. I installed SSC Service utilitry, but the programme could not recognize printer at this status. What can I do?
