20 Most Recent Epson Perfection 1200 Photo Flatbed Scanner Questions & Answers
I posted this for another user but i'll post it here too,
I remember looking for hours for a driver for my Epson 1200 scanner back when I upgraded by dad to Vista 64 Bit, eventually I found one. Just today I upgraded him to Windows 7 64 bit and remembered I couldn't get it to work, luckily I was able to dig up the driver I used for Vista 64. Worked great in Windows 7.
I can't remember where I found it so I can't credit the person who made the driver unfortunately, however i've uploaded it to Rapidshare for you to download. Here is the link:
http://rapidshare.com/files/324940248/epsonScan_1.0_Per1200Win64eu.zip.html
Just open up the zip file and run the setup. :)
Hope this helps, Merry Christmas!
Epson Perfection... | Answered on Jun 01, 2016
That is an older model so I would consider the issue being a bad or failing capacitor on the powersupply or main board.
You need special skill to deal with this.
Epson Perfection... | Answered on Oct 20, 2014
1,Download and install the latest driver for EPSON Perfection 1200.(TWAIN Driver v5.53A)> http://www.epson.com/cgi-bin/Store/support/
Note:The scanner must be disconnected from computer during the installation of this driver.
2.Next download and install Epson Scan! II 32 Utility v2.35E
Epson Perfection... | Answered on Oct 03, 2012
RapidShare is dead.
I used this link today 7-24-2012 and it worked like a charm.
http://www.box.net/shared/5rxsn87mqr
A huge THANK YOU to the person who did the work that Epson
should be doing.
Without the scanner turned on, I downloaded the file, unziped it
and extracted the files. I then ran the .exe
After that I turned on the scanner and let Win 7 install the device.
Simple as pie.
Epson Perfection... | Answered on Oct 02, 2012
should be doing.
Simple as pie.
Epson Perfection... | Answered on Jul 24, 2012
It all depends on what driver you have, it would probably be best if you went to the Epson web site, followed links for support and downloads and downloaded the latest driver for you scanner/operating system.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14557&prodoid=8161&infoType=Downloads&platform=Windows
When I say that, I've just had a look and it maybe the case that this scanner isn't supported for Vista and beyond.
My only other suggestion to use their contact us link and ask them.
Epson Perfection... | Answered on Oct 29, 2010
That is correct, sadly there is no way to make the Epson Perfection 1200 work in Windows 7. Do you have the original disks for the scanner? You can try installing in Windows Compatibility mode, but I do not believe that will work. But to try it, if you have the original software do:
Run the Program Compatibility Wizard
  1. Open the Program Compatibility Wizard by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
  2. Follow the instructions in the wizard.
Epson Perfection... | Answered on Sep 09, 2010
this is pretty ancient model, but... you can try to use winxp twain driver and it should work, your registry most probably will need bit of tweaking... version which will most probably work is TWAIN Driver v5.53A,
follow this procedure, disconnect your scanner from computer, run ccleaner to clean all rubbish, including registry clean.
download twain driver and then run it, force vista to accept it, reboot your computer. connect scanner and you will have then warning from vista about digital signature, disregard it and force install software. scanner should work.
i still would suggest newer version...
Epson Perfection... | Answered on Jul 20, 2010
Epson Perfection 1200 Photo Flatbed Scanner Logo
38 questions posted
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Perfection Epson
  • Perfection Epson
Most Popular Question
epson perfection scanner driver needed
  • Office Equipment & Supplies
