SOURCE: POLAROID 1511-TLXB LCD TV Remote Code for Verizon FiOS STB
I posted that as a point of information. I noted from searches that other people were having remote code problems w/that TV set. Code 0205 worked for me.
SOURCE: Verizon fios remote cant be programmed to control insignia tv
Orion code 0490 solved it for me!
SOURCE: vx37l stopped working with FiOS remote
I read in another forum where Vizio sometimes uses Vidtech codes. I got 0205 to work on my new Vizio V037L with my Verizon FiOS remote (Phillips RC144).
SOURCE: Verizon FIOS remote buttons all work except
I had the same problem with a Sony Trinitron KV-32FS320 32" TV. I reset the remote to factory default.
Then I reprogrammed the TV control.
After this, the volume + and - worked to control the TV.
I hope this works for you.
Jeff Phillips What I did was connec the soundbar audio directly to the Verizon STB audio out and changed the remote to control the STB volume instead of the TV. Then I plugged the soundbar into the switched outlet on the back of the verizon STB.
