I have a side by side and the refrigerator side will not cool. I have replaced heater element and also computor board. What else could be the cause
Gain access to the main control board , behind the refrig . Unplug the refrig . On the board , remove the blue plug , with 3 larger wires . The terminals on the plug , should be : wire1 , wire2 , space , wire3 . Using a short piece of insulated wire , with both ends stripped about 1 /4 " , insert 1 end into wire2 , and the other into wire3 . Plug refrig back in , and look in the freezer section at the bottom , behind the crisper , to see if a red heater glow occures . May take a minute or so . If no red glow , then the bimetal ( the round 1 " piece , with a blue and a pink wire going to it ) clipped on the top right of the coils , is bad ( since you already replaced the heater ) .
If you get a red glow , then the # 4 thermistor is bad . This is the 1 " white piece , with 2 white wires going to it , on the top left of the coils , which is just clipped on also . I would also recommend replaceing the # 5 thermistor , which is located at the bottom of the freezer , on the left , also with 2 white wires going to it . The number 4 thermistor , is the evaporator coil thermistor , and the number 5 thermistor , is the freezer temp thermistor .
it started to play a song and stopped and nothing worked but the blue light, and now it is completly shut down and wont turn on.
I have the problem of the wheel just glowing blue and nothing else. I tried holding the power button down to 'reset' the unit and it worked, once. But now I'm back to the same issue.
