First, I'm not a AMAZON Kindle Tech.
* If it is "Open" (unlocked) then charge it up using the micro USB slot.
* If you can turn it on and the main menu goes on. Swipe the "Padlock" icon to open. Then swipe from top to bottom to get the menu display (for Kindle fire), Paper white will need to press the mode button (only button on the face of pad)
* If this is still a registered device then the regular menu will pop up and you will need to access the device menu by swiping top of screen downward. Select "+More" which will pull up the "Settings" menu. Select "My Account". Select "Deregister" continue and set up your Amazon account.
* If you want to wipe everything and reset the kindle (as giving it away to someone else) then go to "Settings" menu and select "Device". Select "Reset to Factory Defaults" then follow instructions. This will wipe all data and your account info as well as emails, bank records, etc.
* Resetting the Kindle to factory will be the same as if you just bought it from the store. It will automatically go through the welcome screen and help you set up your kindle and give a short beginner's course.
Aloha, ukeboy57
Restart Your Kindle Paperwhite. Many issues with your Kindle, such as a frozen screen or issues with downloading content, can be solved by restarting your device. Help for Kindle Paperwhite (5th Generation). Press and hold the Power button for seven seconds until the Power dialogue box appears, and then tap Restart.
always like to refer to Amazon help whenever possible. I copied their directions for this. Even if your's is not 5th gen it will work. You can also check specific info for your model by logging into Amazon.com Click help, then device help, click on you device and look through the info available.
Press and hold the Power button for seven seconds until the Power dialog box appears, and then tap Restart. Note: If the Power dialog box doesn't appear, press and hold the Power button for a full 40 seconds until your device restarts.
Try swiping your finger across the middle of the screen from right to left. This action turns the page forward. Swiping your finger across the middle of the page from left to right turns the pages backwards. I don't think the icon on the bottom is for page turning.
From the home wage swipe down with finger from the top of your kindle then select "wireless." You will see airplane mode on/off on the right. Select the option you want.
