SOURCE: zenith HDTV 52" double image shadowing all letters
Bad chipset. Possibly a failed solderpiont. More than likely a bad chip. If the set is relatively new, get it repaired, shouldn't be too expensive. Figure 200 or so.
SOURCE: imge is showing double and red
I have over 10 years experience in electronic tech support.
I
know this isn't what you want to hear, but the problem you've described
can't be fixed with troubleshooting. Your TV will have to be repaired.
There is a part that has developed a defect and needs to be replaced. Normally it will cost at least $75 to have the
set looked at by a repair shop (diagnostics). If the part needed to
complete the repair is available, that money will apply towards the labor costs.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from here.
Please let me know if I can be of further assistance.
SOURCE: I cannot ge the convergences
if the convergence went out all of a sudden you most likely need to change the convergence ic's but you need to be careful on where you get them as there are lots of places online that say the ic's they sell atr originals as the cheap Chinese or the knockoffs will sometimes make things worse but if you use originals you should not have too much trouble there is a link I will leave you to get an complete convergence repair KIT at
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
http://www.tvrepairkits.com/xcart/home.php?partner=larry
SOURCE: my Zenith tv has wild
Possible that the lamps are out of alignment resulting in poor convergence of the image.
You might have tto use a test pattern to see if this can be corrected or if this is the fault if the convergence section.
SOURCE: blurry double image on the edge of the tv...
If you have tried to adjust the convergence on your TV within the menu feature then typically you do have a convergence problem. Check out this video to be sure...
sincro?? What does that mean?
