Troubleshooting & Support
Hot Topics:
- color...
- auto...
- auto...
- service menu
- screen
- r49w36
- convergence...
- service manual
- picture
- blue picture...
- looks 3d
- power board
- convergence
- blue tube
- tv repair auto...
- set remote...
- reset button
- tv
- manual
- tv colors bow...
- double picture ...
- convergence ic
- reset
- 3d effect
- repair tv
- blur red
- screen repair
- converge
- turn pip
- pip
- View All »
Problems & Solutions
plug tv in and i get a large snapping sound from
Hi: This is usually an indiction of a cracked flyback transformer or splitter block, the spitter block is responsible for dividing the high...
i just auto convergence my zenith tv and it fixed...
Ur tv convergence ICS are dead.That why ur colors lines green,red,and blue are not linning up,and the colors look like 3-D pic.Must have...
wild colors on screen ive been told it is a
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal....
There is no picture and no sound but the volume
Unplug the cable box for an hour,replug it back in.Should get the cable box to reboot to updated the softwares.Might work than,tv seem to...
have sound no picture any ideals?
sounds like you have a bulb issue you should contact zenith and they will sell you the bulb and ship it out to you you might need a...
CRT Arch / Blue Tube, Now what do I do.
Replace Blue Tube and re-align - Big job and expensive Tube cost min $300 + installation. You can see the tube arching internally?
My red is off. Convergence issue...
Convergence Problem This is a very common failure on Projection TV sets. Screen looks 3D Colors don't line up One or more colors...
how get auto convergence on RCA HD52W59YX38 to...
you can get the repair kit for your RCA at the following link. Its called the ITC222 and ITC222A convergence option missing repair kit,...
The picture on the bottom of the screen has a wavy
Its a convergence problem. You may want to check the site www.tvrepairkits.com. Every thing they said every description was right on. The...
color reset
it must remove the battery that this in motherboard by about three minutes,but with the computer off or you can remove a connector that this...
i have a 40 sony trinitron tv once turned off wont...
The "D" Boards have been big problem causers in these Set's. Unfortunately they are not available from Sony ( At lease not...
I have a Zenith Digital system B (Rear Projection)
Yes, Call Zenith rebuilt boards 1-800-632-6637.
zenith r56w36 56 in
My picture was fine but I had just got cable and wanted to make sure the picture was right. So I hit the auto convergence and now I have a 3...
tv repair
jkhiuhuiguhuyuhuuuyuihuiu
converence
green is fixed so you have to move red and blue to green. by using the remote you may find a simple converge function and open this and...
See all Zenith R56W36 56 in. Rear Projection Television Solutions
Unsolved Problems
tv wont stay on
it turns on. i hear stactic and then it turns back off and red light in front stays on
I turn on tv get the blue deal in middle for about...
auto convergeence has been off for a while
horizontal bars across zenith r56w36
my zenith r56w36 tv has a black horizontal bar that runs across the screen and moves up and down on the screen
Zenith TV
blue curved streak across bottom of the screen .... vibrating lines at the top of the screen ..... blue shadow on any...
My TV a zenit R56W36 is having problems with trac...
My TV a zenit R56W36 is having problems with trac and colors all I see is red green and blue and you can't be able o...
We are trying to watch
We are trying to watch a DVD and this PIP screen will not go away. How can we turn it off so we can watch the DVD?
Is there a manual convergence
Is there a manual convergence on a zenith R56W36? I just see and auto convergence option. Thanks, Les
can get image and sound on my zenith r56w36 only
can get image and sound on my zenith r56w36 only in pip mode. when a switch to full screen i get nothing
Hi was watching tv went
Hi was watching tv went into the kitchen and my zenith r56w36 rear projection tv made a loud hissing sound and then shut...
got a r56w36 zenith no
got a r56w36 zenith no picture but sound, worked when it was in storage moved it to our house and wont work lamps are...
See all Zenith R56W36 56 in. Rear Projection Television Problems
Manuals & Guides
TopDo you have a manual for Zenith R56W36 56 in. Rear Projection Television? - Upload it to FixYa!
Upload a manual for Zenith R56W36 56 in. Rear Projection Television
Specifications
TopKey Features
Full Product Name:Zenith R56W36 56 in. Rear Projection Television
Screen Size:56 inch
Display Capabilities
Aspect Ratio:16:9
Remote Control
Remote Control:Universal
Image Quality
Velocity Scan Modulation:With VSM
Comb Filter:3DYC / 3D Digital
Adjustable Color Temp.:With Adjustable Color Temperature
Audio Features
Audio Output:Variable / Fixed
Audio Type:Virtual Surround
Sound Leveler:With Audio Leveler
MTS Stereo:SAP / MTS Stereo
Secondary Audio Programming (SAP):With SAP
Technical Features
Picture in Picture:With PIP
Sleep Timer:With Sleep Timer
Dimensions
Depth:23.7 in.
Height:57 in.
Width:54.6 in.
Weight:160 lb.
Warranty
Overall Warranty:1 Year
Tube Warranty:1 Year
What's your problem?
Fix-O-Meter
16,196
16,196 people have viewed this product
- 161 people asked about this product.
- 72 people found solutions for this product.
- 3 people have added this product.
Common...
Solution for...
Sony TV Error...
