it's blury and the screen jumps and has lines. It kind of moves up from the bottom squishing the...
(More)
it's blury and the screen jumps and has lines. It kind of moves up from the bottom squishing the screen. in the lower half it is all kinda like wearing 3d glasses
I have the Zenith R49W36 projection tv and posted a problem about pushing the on buttion and the tv...
(More)
I have the Zenith R49W36 projection tv and posted a problem about pushing the on buttion and the tv attempting to come on but then not turning on. I saw a similliar prob where the solution was to replace the fuses. Is this a good idea. If so, how many fuses are there? What do they look like? Where would I be able to pick some up at and what would a rough estimate of the price be per fuse? Thank you in advance.
I have a Hitachi 53UWX10B convergence problem and I changed 2 of the STK392-110 and some conergence...
(More)
I have a Hitachi 53UWX10B convergence problem and I changed 2 of the STK392-110 and some conergence resistors but st have the same problem. So can you please help me which covergence resistors do I have to replace?Thanks!
Television cuts off during broadcast. Sleep timer is not on. It is a Mitsubishi 65 inch rear...
(More)
Television cuts off during broadcast. Sleep timer is not on. It is a Mitsubishi 65 inch rear projection bought 5 years ago. It also takes forever for the green blinking light to go off and get a picture when turned on. Operating on Charter Cable hook up.
double imagen my screen is showing slightly double of all images plus one image is slightly red and...
(More)
DOUBLE IMAGEN My Screen is showing slightly double of all images plus one image is slightly red and the other slightly green!
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
I received a full refund for this tv, Monday Oct 6, 2008. Thomson had a courier pick up this tv at my home 2 weeks ago. Just call the numbers I have...
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
