Check your current input. Use the Source or Input button to ensure that the TV is set to TV mode; there may be one on the TV in addition to the one on the remote. The icon may look like a rectangle with an arrow coming into the box from the left. The Channel Scan option is only available when the tuner is the active input. If you are using a universal remote, you may need to use a different code if the Input/Source button doesn't work. (Some universal remotes don't match this function at all. In that case, use the front panel button to change inputs.)
I can't find the model LED2845A TV. I see a Proscan PLED2845A and an RCA RLED2845A. The Source buttons are in different places on both the front panel and the remote on the two brands. Please add a comment with the brand of your TV if you would like to see where the buttons are for your model.
I hope this helps.
If you have already run the Auto Tuner as part of the quick setup earlier in this guide, please
skip ahead to "Channel Summary" to continue setting up your television. In Auto Tuner Setup,
the TV automatically scans through all available channels, memorizing the active ones and
skipping over blank ones or channels with weak signals. This means you scan using the
CHANNEL +/- buttons), you will receive only clear active channels.
Press the MENU button
?† To AUTO TUNER SETUP
?® To operate
?® To choose CABLE or AIR
Press the OK button to start
Initial Setup
Auto Tuner Setup
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen.
Channel Summary
Channel summary allows you to customize the line-up of channels received by your TV. You
can add or delete channels from the line-up or prevent any unauthorized viewers from watching
any or all 181 channels.
?† To CHANNEL SUMMARY
?® To operate
The Channel summary screen will now be displayed with
the channels set to scan marked with an "?". You can delete
channels from the scan by removing the "?". If any channels
were missed during auto tuner setup and you wish to add
them, you may by placing an "?" next to the channel number.
?† ?® To the SCAN column
Press the OK button to include or delete from scan
Press the MENU button when finished
You can block access to a channel by activating the channel lock.
?® To operate
?† ?® To the Lock Column ( )
Press the ZERO button to lock or unlock that channel
AUTO TUNER SETUP
CABLE
If you wants any codes, contact me through Fixya. Ok
I'm quating these procedure from the manual I've with me, and it is for JVC AV32S565.
