I'm looking for advice as to the best Bose input for SACD (contains 5.1 information) captured to FLAC and played back by computer (Analog Line out currently but considering adding digital out): 1. Bose Aux in 2. Bose Digital in Regarding option 1. The Bose manual states the following which makes me think that Aux is the right decision: Setting up a digital sound source Connect a DTV or DVD player's digital signal directly to the female RCA jack on the audio input cable. Connect the DVD player's analog signal output to the AUX inputs. If your Lifestyle® system receives a valid digital signal (including PCM or Dolby Digital bitstreams), this digital sound is used. If no valid digital signal is received, then your system selects the analog signal being sent to AUX, which is then processed by the Videostage® decoder for excellent home theater sound. If your digital audio source has an optical connector, you will need an adapter with an RCA (coaxial) connector. Consult your dealer or contact Bose® Regarding option 2. I've read the following (not in Bose manual): A coaxial digital audio connection is used to send S/PDIF digital audio signals between devices. It supports uncompressed PCM stereo audio as well as DTS and Dolby Digital 5.1/7.1 surround sound signals. It does not support DVD-A, SACD or high-definition audio such as DTS-HD Master Audio and Dolby TrueHD. So in summary: The Aux in is analog but processed by the Videostage® decoder. The Digital in supports 5.1 and should be cleaner/quieter being digital I expect. I'd be interested in onions from other that know for sure what's better or have done this. thanks
At the back of the Bose Solo are three different audio inputs. Optical digital-IN, coaxial digital-IN and Cinch (RCA) (white and red) analog audio-IN. You should check if your TV has an optical digital-OUT, coaxial digital-OUT or an Cinch analog-OUT connection. you need at least one of these three connections. If not, there is no possibility to connect your Bose Solo to your TV. If you use a SETOP-box to watch TV, you could check if it has one of these audio outputs. If it has, you can connect your Bose Solo the your SETOP-box.
sounds like you have it set correctly..do you have any other sources than external,(such as audio out) ?If so that should solve your problem...does the system have any other connection outs, such as red white audio cables (LR audio )? You can use them as external when the optical is unplugged...if you get sound you either have a bad optical cord or the output for it is defective..good luck GOD BLESS
hello! unless your "Bose" has an optical or coaxial digital stream audio inputs, there is no way of connecting TVs audio output to your receiver(home theater). to by pass the TV itself, connect analog audio output off your cable or set top boxes. those, still have analog audio out. If you need to connect more audio sources, use TV as a video monitor, connect all the audio outs to your "Bose", instead. In case of terrestrial broadcast, you may need to obtain digital converter box and use it simultaneously with TV to get your audio out. Also, if you lack DVR, that box will allow you to use regular DVD recorder. It's not going to be HD quality, but better, than nothing. You can't feed HD video signal out of TV set.Only analog. good luck, Alex.
hi, u have to change the digital out setting of ur blueray player. change the audio output priority from HDMI to optical coaxial. surely u will get audio from bose. ok
hi, do the following. 1. connect ur blue rays hdmi out to ur tvs hdmi input. 2. connct blue rays out to any one of the coaxial(aux) input of bose. 3. connect ur tvs optical audio output to optical audio input of bose 4. connect monitor out of ur bose to any one of ur av in of ur tv. connect component video to better quality . 4 . in the blue rays audio setup select audio output priority as optical/coaxial 5 . in bose set aux as digital input. to see blue ray select hdmi of ur tv, sellect in bose in which the blue rays coaxial is connected(aux) insert disk in blue ray an watch to see dvd in bose select tvs corresponding input, select bose to dvd . insert dvd and watch to whach tv program set tv to corresponding mode. set bose to optical audio input mode. ok
Hi! It would just be easy. Just prepare RCA cables and connect the cables to the tv and satellite receiver. Link the TV and satellite audio output to the BOSE audio input. Good luck and have a good one!
Well, if analog works for you connect the CD player's analog RCA cables to the VCR inputs.
Can you imagine why you NEED to have the TV audio coming into the receiver from the TV? Are the TV's audio system or speakers superior to the audio section of every other source of TV-related programming? We hope not. Does the TV receive any programming that the receiver can not? Maybe games. I imagaine this MIGHT justify running analog TV audio back to the receiver.
Your cable box and your DVD player have both digital and analog audio outputs. The gray area is what your TV has for audio inputs. It could survive with simple RCA analog audio in from both and none to or from the receiver. Then you could watch Lo-Fi cable and DVD's without the receiver turned on.
That would free up the TV analog audio input for other things.
I imagine your DVD player is using one of the digital inputs on the receiver. If you have one each optical and coaxial audio output among your DVD and Cable Box you could place them in the two available diigital inputs.
Now, what about the CD's digital output? For stereo music you're not likely to be able to hear any difference between it and the analog input BUT it can still be connected digitally IF it has a coaxial output. Coaxial digital inputs can be shared.
Get an RCA-splitter and join the two units entering the coaxial audio input just before they enter that connection. Either will work just fine if you TURN THE OTHER ONE OFF when you want to us it.
I had the same problem with my 321 system. The fix is in the cable box settings. You want to change the Digital Out on the cable box..my choices were HDMI....Dolby Digital..and None. Choose Dolby Digital and it will show up on your Bose 321 display. I also have my cable box connected to my bose system via optical digital cable...and a digital coaxel cable from my dvr to my bose. Change that output setting on my cable box took care of the PCM 2.0 problem for me.
