20 Most Recent TCL L32D20 Questions & Answers
perhaps it is because you do not change the input or source t the player as you should have it on a different input like hdmi
TCL L32D20 | Answered on Mar 15, 2019
Check your router to see if the MAC Filtering feature is in use. If it is then you will need to add the TV's MAC address to the list of permitted devices before the connection will complete.
TCL L32D20 | Answered on Jan 26, 2019
put it off
TCL L32D20 | Answered on Feb 22, 2017
Is there a reset button? Have you contacted customer service at TCL? Check your manual?
TCL L32D20 | Answered on Oct 06, 2016
It will jump head over heals; when the TV works.
TCL L32D20 | Answered on Aug 26, 2016
Not Possible without remote.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
TCL L32D20 | Answered on May 01, 2016
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
TCL L32D20 | Answered on Apr 20, 2016
TCL L32D20 | Answered on Mar 04, 2016
First of all, read the manual that came with it, and if you don't have the original, look online for it, and search for the default PIN number(usually 0000, or 1234). If it has been manually changed by a previous owner, try asking them. If that doesn't get results, see if there is a Master pin # for the TV, and enter that through your ORIGINAL TV remote. Sometimes Universal ones work, but I wouldn't hold your breath. I have an ex-hotel flatscreen Philips, and it took me ages to find out that it had a Master Remote, and a secondary one for guests, and the Master one could alter the functions, like lock out the HDMI plug(to discourage plugging in your laptop, and force you to watch PPV TV, oh, yay), and I finally tracked down the master unlock for it.
Another option is, if it's a digital TV box, contact the manufacturer, and see if they can help, in regards to resetting the unit to factory settings. It will mean you will need to retune your TV to get the channels, but at least you can then chose your own passcode.
Hope that helps, and cheers from New Zealand! ;)
Pete
MegaByteMe
TCL L32D20 | Answered on Feb 10, 2016
Do you want a answer to this above question or can you submit a sensible question?
TCL L32D20 | Answered on Sep 25, 2015
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase " how to test a remote control " in its search box at the top right of the display window to get the related post quickly.
TCL L32D20 | Answered on Jul 30, 2015
Never heard of such a thing sorry.
TCL L32D20 | Answered on May 17, 2015
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
TCL L32D20 | Answered on May 12, 2015
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability.
Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
TCL L32D20 | Answered on Feb 24, 2015
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
TCL L32D20 | Answered on Feb 15, 2015
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
DirectTV remote control code list is given.
TCL L32D20 | Answered on Oct 15, 2014
TCL L32D20 Logo
49 questions posted
Top TCL Televison & Video Experts
MegaByteMe
MegaByteMe
robert
Are you a TCL Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • TCL Televison & Video
Most Popular Question
turn off many times fine tuner get
  • Televison & Video
