Samsung UN65H6203AF 65 1080p LED-LCD TV - 16:9 - HDTV 1080p - ATSC - 1920 x 1080 - DTS Premium Sound 5.1, DTS HD, Dolby, DTS Studio Sound - 2 x HDMI - USB - Ethernet - Wireless LAN - PC Streaming - Internet Access - Media Player Logo
Ana Faria-Aguiar Posted on Aug 16, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Samsung un65h6203afx and the screen is completely distorted with colored lines. Anyone have experience
Level 3:
Top Expert:
  • Samsung Master 76,851 Answers
  • Posted on Aug 16, 2016
Samsung Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008675
Points
237762
If you wish to get some details; check the site linked here. Pull up older posts.
https://youtu.be/wUpnETSm6_k
1helpful
Samsung Plasma pn51d550c1fxza 3D TV developed colored vertical lines that sometimes meld into the picture but do change color at times
The symptoms you are describing with your Samsung plasma TV are consistent with a failure of the plasma display panel or a failure of the plasma drivers that control the display Here are a few things you can try to troubleshoot the issue:
  1. Check the connections: Make sure all the cables and connections to the TV are secure and not damaged. Loose or damaged cables can cause visual distortions on the screen.
  2. Perform a factory reset: Sometimes a factory reset can fix issues with the TV. Refer to the TV manual for instructions on how to perform a factory reset.
  3. Check the internal components: If you have experience working with electronics, you can try opening the TV and checking for any obvious damage or loose components. However, be aware that opening a TV can be dangerous and may void the warranty.
2answers
There is a humming in back of tv.the sound always good but picture doesnt come thru and i get a green screen someetimes blurry with distortion.color wheel or dmd chip or lamp starting to go out
as my experience, the most possible reason should be the color wheel or its photo sensor board.
firstly try to clean its photo sensor board, or have to replace a new wheel.
i just have this wheel, when you need to replace it, contact me freely
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
5helpful
Picture on Samsung lcd LNT5271F is blurred sometimes lines color distortion double images then goes away and will come back. Part of the screen will go completely lines then come back. Starting to happen...
Had this exact problem diagnosed by a local repair shop as a bad LCD panel. According to the technician there's a loose ribbon cable on the panel and it would cost as much to replace/repair as a new TV.
My Samsung HL-S5065W will turn on, it makes a humming noise. The picture comes on after a 1 minute or so the screen will go black and the tv shuts down. What could this be?
Hi,It sounds like you might be
experimenting a color wheel problem.The
color wheel is a rotating disc that has a
gamma of colors it spins at high rpms.The
light of the lamp goes through it to create
the colors on your tv.When it starts to go
bad you will hear ,humming,buzzing,high
pitch noises ,you might also experiment
color distortion ,black and white
picture.Here's a link that will help you
replace it:
http://www.fixyourdlp.com/guides/samsun
g/bp96-01579a.php Part # is BP96-01579A and you can find it here: http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm?Click=48173 Have a blessed one!
1helpful
Loud humming sound on with a purplish and pinkish screen on my 50 inch dlp samsung, 5 yrs old.
Hi,sounds like you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Your part # is BP96-00250A You can find it here http://www.discount-merchant.com/Samsung-BP96-00250A-ColorWheel-Assembly-p/bp96-00250a-color-wheel.htm?Click=48173 and here's the instructions to replace it : http://www.fixyourdlp.com/guides/samsung/bp96-01579a.php Have a bless one!
After changing color wheel on my samsung hlr 5067w tv my picture is high with black bar on bottom.top of heads are cut off.what went wrong? no proble before.
Hi,If you are experimenting vertical lines ,black bars ,color
distortion,pixilation,or white dots on the screen you might be having an
issue with the Dmd chip.This is how the DMD chip works:
http://electronics.howstuffworks.com/dlp1.htm Basically the dmd chip
is composed of around 2 million pixels that create the image on the
screen.You will need to replace in order to fix your problem.Have a
blessed one!
Concave tv screen colors distorted just had tv repaired one year ago for same problem
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
